Oil cooled piston 190 XT |
Leon B MO
Joined: 12 Sep 2009 Location: Old Monroe, Mo Points: 2210 |
Topic: Oil cooled piston 190 XTPosted: 20 hours 10 minutes ago at 3:15pm |
In the process of rebuilding a very tired Series 3 XT. We've had the tractor for 15 years and little by little it got harder to start. Very low compression. We have no prior history. The main bearings have 74 stamped in them and rod #1 has the serrated cap, so someone has been in there at some point. Going to check out the head and have the pump and injectors redone. Pump guy said it was wore out.
So got the kit and the main bearings have the oval hole for the piston cooling and the block has the port as well, but the bearings we removed had just a hole and would not have fed oil to the cooling ports. Just to be sure, it's ok to use this style bearing without a loss of oil pressure issue. Thanks Leon B MO
Edited by Leon B MO - 20 hours 8 minutes ago at 3:17pm |
Posted: 19 hours 52 minutes ago at 3:33pm |
An XT block doesn't have the small hole (.040") drilled in the upper main brg saddle for piston cooling. So, even tho the upper bearing shell has the delivery slot, the oil has no place to go. Will work fine.
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8769 |
Posted: 11 hours 54 minutes ago at 11:31pm |
Doc says that block doesn't have oiled holes in main saddle. You say it does. I was you and it has holes. I'd drop crank and plug them. Uppers will have less wear so you could plastigage old upper with new lower and reuse?
Posted: 8 hours 6 minutes ago at 3:19am |
I think the hole he is referring to is the main oil feed hole to the bearing. Anyway, that's how I interpreted it.
