Oil cooled piston 190 XT
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: Oil cooled piston 190 XT
    Posted: 7 hours 24 minutes ago at 3:15pm
In the process of rebuilding a very tired Series 3 XT. We've had the tractor for 15 years and little by little it got harder to start. Very low compression. We have no prior history. The main bearings have 74 stamped in them and rod #1 has the serrated cap, so someone has been in there at some point. Going to check out the head and have the pump and injectors redone. Pump guy said it was wore out.
So got the kit and the main bearings have the oval hole for the piston cooling and the block has the port as well, but the bearings we removed had just a hole and would not have fed oil to the cooling ports. Just to be sure, it's ok to use this style bearing without a loss of oil pressure issue.
Thanks
Leon B MO
Edited by Leon B MO - 7 hours 22 minutes ago at 3:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 7 hours 6 minutes ago at 3:33pm
An XT block doesn't have the small hole (.040") drilled in the upper main brg saddle for piston cooling. So, even tho the upper bearing shell has the delivery slot, the oil has no place to go. Will work fine.
