oil control rings into cylinder liner
WaltDevore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Topic: oil control rings into cylinder liner
    Posted: 06 Aug 2020 at 7:48pm
I've been trying all day, more precise than ever in my life, yet cannot get them into cylinder liner.  Using standard piston ring compressor.  Is there a trick?  This costing me days of futility.  Thanks for any ideas.  On 271 engine, GM Diesel, two cylinder, 1951
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 8:16pm
Try a ring set, alone, sans piston.  You may have the wrong ones, or they might need fitting...Wink
Acdiesel View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 9:17pm
you maybe saying the same thing, but remove the rings from the piston and see how they fit in the cylinder.
there should be some gap in the ring ends when installed in the cylinder bore.
Dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 06 Aug 2020 at 10:31pm
I finally figured out which control ring was the chrome.  They all looked the same.  The diagram in the package showed slotted and non slotted, I think I've figured that out although they seem very close to the same.  Had no idea this was literal rocket science.  The kit also has main bearings that I don't think I could install or need, but now I see it may be possible with the engine still in the tractor.  It's starting to osmose to me these four halves of "thrust" bearings.  I have no idea how difficult they may be. This whole process has been a scary gamble.  Will the end ever come?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 12:00pm
Are you loading this from the BOTTOM of the Liner?  The bottom lip is relieved for ring entry, the Top is NOT.  Pistons/Rods and Sleeves are assembled to these engines as a Unit not individually.  I used to own sleeve loading units as this, made life simpler for a mechanic.
Edited by DMiller - 07 Aug 2020 at 12:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 12:41pm
Very easy to break oil ring using regular compressor even though going in the tapered bottom
Post Options Post Options   Thanks (0) Thanks(0)   Quote WaltDevore Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 1:27pm
Yes, I already have broken some and got new ones.  When you say regular compressor, it seems I need an irregular one.  What might that be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Aug 2020 at 6:30pm
Need to make absolutely certain a wrap type compressor is square and not barber polled when install piston, has to be in full contact with sleeve until rings are in the bore.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Aug 2020 at 9:10pm
The compressor you need is in that video link. Find a truck shop that still has one and take your stuff there and pay them to load your liners
Edited by SteveM C/IL - 08 Aug 2020 at 9:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2020 at 10:58pm
Did you ever get this whipped?
