Oil change WD45 |
Post Reply |
Ed (Ont)
Orange Level Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1205 |
Posted: 21 Jun 2022 at 7:26pm |
Did an oil and filter change on my old tractor. Doesn't get used much so has been a few years since I did it. Used Shell rotella 15-40 but the older spec oil in the black pail. New filter from Agco. Really brought the oil pressure up - now constant on the high end of the gauge. Stays on the "L" in normal on the face of the gauge. It had 5-40 synthetic in it before and the pressure wasn't as good. I think the non synthetic is better for these old girls! Winter starts may be a bit harder tho.
exSW
Orange Level Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Thanks(1)
Use that oil in my WD. Fires up just fine in the cold.
Learning AC...slowly
Aaron123
Bronze Level Joined: 14 Apr 2020 Location: Monroe WI Points: 82 |
Thanks(1)
I use Rotella 15-40 in my wd45 and it seems good.
The guy that owned it before me put it in most engines he has.. they even put it in there dodge minivan. Lol |
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7910 |
Wally world 10-30 full synthetic in my 45
Robert Musgrave
Silver Level Access Joined: 11 Sep 2009 Location: SE Wisconsin Points: 224 |
Dad's 1949 WD spent its first 40 or so years using SAE 20W-20, now has 10W-30. As far as pressure, the book says that "oil pressure is sufficient when the needle on the gauge is between the O-R-M in the word "Normal" on the guage! O, for the sake of simplier times! R. Musgrave
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11380 |
You went from 5 viscosity at start up, to 15 viscosity at start up. Yep, your oil pressure will be higher.
Ed (Ont)
I'm not talking about startup. That is fully warmed up to about 170 degrees F. Drove it a few miles. Top number is what counts when it is hot - both are 40 so should be close.
Engine is 226 gas just to clarify. It stays at 170-175 constant even on hot day. Not trying to start any argument here. Just sharing some observations as the oil discussions seem to appear here once in a while.
Edited by Ed (Ont) - 23 Jun 2022 at 9:27pm |
Post Reply | |
