Oil change WD45 |
Ed (Ont)
Joined: 08 Nov 2009 Location: New Lowell, Ont Points: 1595 |
Topic: Oil change WD45Posted: 21 Jun 2022 at 7:26pm |
Did an oil and filter change on my old tractor. Doesn't get used much so has been a few years since I did it. Used Shell rotella 15-40 but the older spec oil in the black pail. New filter from Agco. Really brought the oil pressure up - now constant on the high end of the gauge. Stays on the "L" in normal on the face of the gauge. It had 5-40 synthetic in it before and the pressure wasn't as good. I think the non synthetic is better for these old girls! Winter starts may be a bit harder tho.
exSW
Joined: 21 Jul 2017 Location: Pennsylvania Points: 914 |
Thanks(1)
Posted: 21 Jun 2022 at 7:44pm |
Use that oil in my WD. Fires up just fine in the cold.
Learning AC...slowly
Aaron123
Thanks(1)
Posted: 22 Jun 2022 at 6:54pm |
I use Rotella 15-40 in my wd45 and it seems good.
The guy that owned it before me put it in most engines he has.. they even put it in there dodge minivan. Lol |
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8984 |
Posted: 23 Jun 2022 at 6:24am |
Wally world 10-30 full synthetic in my 45
Robert Musgrave
Silver Level Access
Joined: 11 Sep 2009 Location: SE Wisconsin Points: 246 |
Posted: 23 Jun 2022 at 9:54am |
Dad's 1949 WD spent its first 40 or so years using SAE 20W-20, now has 10W-30. As far as pressure, the book says that "oil pressure is sufficient when the needle on the gauge is between the O-R-M in the word "Normal" on the guage! O, for the sake of simplier times! R. Musgrave
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12422 |
Posted: 23 Jun 2022 at 11:31am |
You went from 5 viscosity at start up, to 15 viscosity at start up. Yep, your oil pressure will be higher.
Ed (Ont)
Posted: 23 Jun 2022 at 9:22pm |
I'm not talking about startup. That is fully warmed up to about 170 degrees F. Drove it a few miles. Top number is what counts when it is hot - both are 40 so should be close.
Engine is 226 gas just to clarify. It stays at 170-175 constant even on hot day. Not trying to start any argument here. Just sharing some observations as the oil discussions seem to appear here once in a while.
![]() Edited by Ed (Ont) - 23 Jun 2022 at 9:27pm |
