OH gosh,,another Ranger,,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: OH gosh,,another Ranger,,,,,
    Posted: 17 Sep 2019 at 11:21pm
  Well Lookin like ole Shameless is just gonna have to chew my azz out again as I come dragggin home yet another Ford,,,jimminy,,,,,
 I seen this 1992 Extended Cab with a 4.0 5 speed with 4X4.  the guy says "Not Runnin" and wants $1000, I wait and a few days later the price is $750, then down to $500 and when it gets to $300 I message him and he tells me come look and bring a trailer. I ease up to the Alien Town and it don't look too bad,,,nuttin a wash rag and a bucket of water won't fix,,,,He tells me his friend GAVE it to him as he could not get it runnin after 3 weeks of tryin. After we get it loaded on trailer he tells me since his friend GAVE it to him,,,he is gonna GIVE it to me as well,,,,I'm impressed,,!!
  He tells me it will not crank at all and after getting it home I find the cable from battery to starter is bad plus the brushes are shot in the starter. After fixin these 2 things it will now crank but NO Start. The engine spins free  like no compression so I pull plugs and engine has NO Compression at all,,!!!
 I'm told by a dude on The Ranger Station Forum that the 4.0 is a non-interference engine so no valves should of hit the pistons to explain the no compression issue .
 I figure timing chain broke but doesn't explain the no compression sitiation????
 Any takers,,,
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 12:18am
goin ta hafta call the ol desert rat the Danger Ranger...
  Or would that be the dangerous ranger... ah, maybe the Ranger Dangerous...
  mmm the Dang ol Rangerous  ... Roger dat an eye is out-ta here
Broke crankshaft at the front of rear bearing by the flywheel?
maybe the rings are all stuck?
 broke rods on all the cylendricals...?
mmm stuck valves on all the cylinders... from no lube to the top of the head.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 6:43am
It sat a while then someone started it and the valves stuck from the crappy gas we get today. Pull the valve covers and give it a look. Belt or timing chain??? No cam movement no compression.
Crank it over and watch the rotor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 8:06am
Humm should be interesting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 8:32am
im with Thad... if the pistons are going up and down, and the valves are not opening or closing, then you will not get any compression.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 9:38am
 LOLLOL,,,Well,,Ya'll see,,I was in a hurry to post and haul azz 'fore ole Shameless started pokin me bout this Ranger ,,so I didn't get to do a Paul Harvey and do a "Rest Of The Story",,,,,LOLLOL thet Shameless,,,he gots sharp words agin them poor Fords,,,,,
 Anyway,,the original owner,,,trk is low mileage at 81,250,,he was drivin home from work and engine made a noise and stopped runninquick. After that he never could get it to run, not knowin too much bout trks. Then the second owner didn't know too much hisself and had several shade trees look at it with no luck either,,,so,,,along comes ole Shade Tree Expert Joe,,Clap
  Don't know if ya'll remember but My neighbor Lady had given me a even lower mileage 1996 Explorer wit  the same 4.0 before she passed away and I never done nuttin with it but park it down on lower 40. Now,,,I can either open the front of this engine up for a look see,,and possible quick repairs,,OR,,I can go ahead and pull BOTH engines and install the explorer engine in the ranger,,,,BUT,,,,the original owner told the second dude that engine did not use any oil and I can see that by the spark plugs and the tail pipe shows NO oil burning.
 Me being a sort of quizzical and adventurous person, I'm curious what happened and since I'm also gettin older and some lazier, I'm thinkin bout openin up the front to see if a "quick fix" is possible,,,???
 Hey JC,,,you remember thet dude that was or is still married to hillary's woman partner,,,Umma something,,,Carlos Danger,,,,,I kinda like that one,,,,,LOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 10:23am
John Lennon was married to Hillaries friend
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 11:16am
yoko ono first response to Trump's win...
   sounds more like a sick cat dying...
[TUBE]G_pG1vX7T-s[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 11:23am
Do y’all know what Yoco wanted most for the Beatles???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 11:35am
Les Paul
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 4:41pm
 Hey Thad,,,you mean ole UMMa Abedin was married with ole John Lennon...???  Was that before she hooked up with ole Carlos Danger,,,,,shure enough,,?? LOLLOL(else I missed the punch line)
That UMMa us an ugly sob,,but she must be well versed in the art of pleasin ,,,,,but then Yoko wasn't too easy on the eyes either,,,,,,so,,,she musta been a whale of a squeezefor ole John to keep her around so longWinkWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 18 Sep 2019 at 10:43pm
the price of the Chevy Allis just went up!
this stick sharp nuff?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 1:34am
 Ouch, ouch, ouch, ouch, no more Shameless ,,,no more,,,AY, yi, yi
 Chit fire you drive a hard bargain
 UMMmmm,,,didn't you say you' take small payments,,,,???LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 1:36am
 wait just a goldurn minute,,,,Shameless,,,what does ole UMma Abedin have to do with My Chevy Allis,,,or, or,,John Lennon or,,even,,that Carlos Danger guy,,,,,,,???LOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 9:39am
DJ, Thats what I was wondrin too...
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 1:09pm
Dang it Shameless Wink you have him distracted he ant ever going to concentrate and figure this little gem out.LOL Why with that low miles I might have go look all my rides are over 200,000 most 300.
An all you others Confused that have him mooning over Yoko. Joe you might as well drag this down to the lower 40 too and forget it like the widows Ford.
Edited by Ray54 - 19 Sep 2019 at 1:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 2:43pm
  Hey Steve,,,you mean that even if the pistons are going up & down,,,and all the valves are closed,,it will not build compression,,,???
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 2:46pm
 CHIT,,chit,,chit,,after thinkin on what you said,,,,there's no way it can build compression in the chamber until the intake valve opens to let the piston coming up squeeze the compression,,,,,,,,,
  UM,,,,
  CHIT,,,I KNEW THAT,,,!!!,,,I'ma go find me a hole,,,,,,,WinkLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 2:55pm
I’m guessing stuck open
trace View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote trace Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 3:10pm
hey, i have a 99 rord ranger xlt with 205,000 miles on it. very reliable truck. my go to to go to town and not bad mileage either. bought in 2008 with 58,000 miles on her for $3000. been well worth the money.
1955 WD-45 WIDE FRONT W/ TRIP
LOADER
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 3:11pm
  Well,,,suppossedly a dude on The Ranger Station forum told me this 4.0 was a Non-Interference engine,,,so if the valves cannot hit the pistons ,,,,how did all 8 of the intake valves get bent,,,,?? Have to be the intake valves because of the higher lift
 Guess  I oughta open the front up but ain't wantin to start another project just yet as I'm wantin to get back on thet obama Silverado cause I gots an update that them Chevy Boys here is just flat gonna wanna pat me on the back,,,,,Clap
 See ya at the other thread,,,,,,,Clap
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 3:40pm
Not bent stuck open from bad gas. Happens often when they’ve sat for long.
Neighbor bought a 93 F250 at auction. Very low miles very nice(pristine) condition. Old man that owned it died. It sat in his garage for 3 years or so. Started and ran good. Neighbor bought it filled with gas and headed home but never made it. Valves stuck open from old gas. Machine shop says they deal with it often.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 5:06pm
I was leaning toward broken chain........ some valves OPEN, some CLOSED... no compression if your not getting air IN, then CLOSING the valve.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2019 at 8:43pm
Joe, pull the valve covers and see how many of the rocker arms are rockin' and how many ain't. Then tap the valve stems and see what happens. May turn out to be a broken cam.    Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2019 at 4:42am
After reading a little I see these are SOHC engines. Not uncommon for one side or the other to jump time and the cam not rotate.
Just for fun check compression on both sides, if you haven’t.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2019 at 5:01am
 Hey Thad,,,I did check #5 (middle) plug cylinder on passenger side as it was the only'ist one I could get to without removin a bunch of stuff,,,and it was zero as well,,,Plumb puzzling,,ain't it,,??
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2019 at 5:05am
 Soon's I get a little time from the BBC project,,I'm gonna do like ole Leon says and pull the left side valve cover,,not too awful a job to get it off,,,this has got me buggered not knowin what happened,,,,,,,LOL
This page was generated in 0.115 seconds.
