Off-color disc parts needed
Keith inMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith inMN Quote  Post ReplyReply Direct Link To This Post Topic: Off-color disc parts needed
    Posted: 18 Mar 2010 at 6:53pm
I need a part for a JD disk or contact info for a salvage yard that might have the part.
I need a spool or spacer for the axle, where one of the hanger clamps mount.
The cast in part # is B13889B. It is 8 1/4" long. The large end is 4 1/2" outside diameter. The small end is 3 3/4" diameter.  The middle is 2" diameter and about 3 5/8" between the flanges.  The axle is 1 1/8" square but the spool I.D. is round.
Any help is appreciated.
Hopefully the pictures attach.
Edited by Keith inMN - 18 Mar 2010 at 6:57pm
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 10:19am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith inMN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 5:25pm
Thanks for the link. I searched their site and no luck. This model must not have been made for very long.  Most salvage places don't have any parts and most aftermarket suppliers don't bother to make these parts.  I'm hoping someone knows of a good salvage yard or knows of a disk parked in the weeds that can be cannibalized to keep another one functional. It looks like the easiest thing to look for is the length of 8 1/4 inches.
Tim in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in NC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 6:12pm
Wow, $120.00 from mother Deere!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 6:34pm
Maybe you could buy a chunk of cast iron 4 1/2" OD by 8 1/2"" long and chuck it up in a lathe, make some chips and you'ld be in business.It would cost you more than $120 if you hired it done I'm sure.
Edited by CTuckerNWIL - 19 Mar 2010 at 6:35pm
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2010 at 7:08pm
Keith there used to be a large boneyard south of Long Prairie that had a lot of old disc's out back, where in central MN are you located at?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith inMN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2010 at 10:35am
Darrell,
I'm located near New Prague.  Do you have a phone number for the Long Prairie yard?
I've called Larsons/Cambridge, Hofland, Gotvold, Darwin and a couple others I can't remember at the moment.  I must have a real odd duck with the 8 1/4" spacers.  Everyone has loads of the 7 1/2" parts.
Thanks for any help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2010 at 9:49am
Just make it out of steel.
Did you try Shoup?
This page was generated in 0.088 seconds.
