Off topic - IHC skid steer loader |
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Topic: Off topic - IHC skid steer loaderPosted: 21 Feb 2016 at 12:05am |
I've got an old IHC 3300B skid steer loader with a bad loader hydraulic pump. I've spent hours searching the internet for information or parts for it, haven't come up with anything yet. The pump is a TRW H, IH # 68576 - C91 190. What seems to make it unique is it has a tapered drive shaft with a key for the gear. Got a pump at Surplus Center a few years ago but it has a straight shaft. Might be able to somehow grind out the gear but wouldn't be easy. Probably too hard to do in a lathe. Any Ideas?
Allis Express participant |
darrel in ND
Joined: 22 Nov 2009 Location: Hebron, ND Points: 8779 |
Posted: 21 Feb 2016 at 1:27pm |
I would sure think that as big as Denver is, someplace there would be able to help ya out. A generic hydraulic shop ought to be able to fix you up. I (actually my wife) just bought an IHC skid loader, model 3200 A, and I hope we don't get to having trouble finding parts. Darrel
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 21 Feb 2016 at 4:51pm |
I replaced a pump on a New Holland skid steer - found the same pump with a different shaft - (NH had lock on the shaft for mfg rights) just replaced rotor , housing and everything but shaft with second pump parts - 1/4 price of NH unit.
Same with some valves that went into control - NH was $250 + and so called non serviceable - units I got were $70 and used a snap ring retainer for internal parts where NH had a swedged permanent closure which made service impossible . |
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 06 Mar 2016 at 6:35pm |
did IHC make their own or was it re-badged?
CTuckerNWIL
Posted: 06 Mar 2016 at 7:33pm |
I doubt the bore of the gear is hard. If you can score it with a file, you can bore it on a lathe. If it is hard, I have rigged a die grinder in a lathe to use as an ID grinder.
