Off Topic For Sure .....
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Off Topic For Sure .....
    Posted: 08 Sep 2020 at 5:34pm
But I've read in the past about IH corn heads with  "water pump" bearings ?? Are the bearings literally cooled with water ?? I've never been around one Wink . Thanks
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 5:56pm
Just a style of bearing,, likely used in water pumps...sealed 2 row ball bearing with a shaft extended on one end...maybe one that is more better with a puter will put a picture...
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 7:37pm
Wink
I am a Russian Bot
Andrew(southernIL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew(southernIL) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 8:37pm
Our 1063 head has them, its pretty nice not having to grease anything on the rollers.
If fishing is a sport your looking at an athlete
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 9:02pm
Next question:  do sealed bearings  really have a seal in them?Wink
[TUBE]J53UK_bul5Y[/TUBE]
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2020 at 9:52pm
When I worked at CaseIH dealer I remember some were changing their older heads over to water pump style, a couple years ago some guy with a 1660 or something told me the older bushing style was less problematic and cheaper to maintain as long as you kept them greased........ you can always find an opposite opinion I guess.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 5:32pm
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2020 at 8:37pm
Originally posted by FREEDGUY FREEDGUY wrote:
Thanks Lonn, those are not quite what I expected a "bearing" to look like LOL!!
That's exactly why they're referred to as 'water pump' bearings... it's not a typical sealed cartridge, or pillow block, flange, or needle roller bearing.
Water pump bearings are primarily used in a housing where one end is on the fanbelt sheave, the other end is on the impeller.  In doing so, there's really only one machining process for making the centrifugal pump work... bore the axis from the volute through the casting nose, and it's done, and the only 'fancy' part, is the cutting head on the boring tool... alignment is perfect in one shot.  Combine the unitized pump bearing with a mechanical seal and a cup, you've got an entire rebuild kit in one nice little box.
The fact that it's a unitized assembly (bearing with shaft) has some other advantages... the shaft is actually the running surface for the rollers, so the total assembly is much more compact, and there's no need to worry about clearances and bearing preload, just push the cartridge in and be done.
It is for the reason of compact simplicity, that water-pump bearings get used for all sorts of 'other' tasks.  When the world of CNC appeared, manufacturers realized that they could drill a hole in the shaft end, and thread it for a bolt or stud, and use the water pump bearing cartridge as a high capacity precision roller guide, or as a 'cam follower', hence it now is used for all sorts of things... and for that reason, production volume is much higher, which makes commensurate costs LOWER, and that is reflected at by lower price across the sales counter.  Handy things, they are...Wink
