Off color question
48ACWD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Topic: Off color question
    Posted: 16 Mar 2018 at 9:32pm
Buddy of mine is building a ford 7000 tractor to run in our stock series classes. He is putting in a 304 genesis motor but ran into oil pan issues. Wide front end attaches to the pan so tried using original pan from the engine that was in the tractor bolt pattern is the same but does not clear the balancing gear set that the 304 uses. Just curious to see if anyone has or knows someone that's done this swap before. Any info would be a great help. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2018 at 10:30pm
Curt Forrester from  somewhere in Pennsylvania is the guy to talk to.
bsallis180 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 5:06am
Chambersburg Pennsylvania google the store Forrester farm equipment and ask for curt if not available ask for Cory, Curt is on the road a lot
Post Options Post Options   Thanks (0) Thanks(0)   Quote bsallis180 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 5:12am
Tell me I thought the Genesis was named after the 70 series tractor and that’s only a 456ci 6. Cylinder?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 48ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2018 at 7:38am
Thanks guys, I'll give them a call and see what they say.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2018 at 7:28am
The "Genesis" tractor was generally a 456, yes.  The 4-cylinder version of it was 304 cubes and had all the design features of the 6 cylinder used in the Genesis tractor line.  The medium duty truck version of that 6 cylinder engine was a 474 cube displacement. Pre-Genesis engines were a 401 and date back to the early 1970's.
Acllss puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acllss puller Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2018 at 4:56pm
Hey Brett you making any upgrades on yours this year ? Ie 426 in it ! Lol
