Off color question |
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5156 |
Topic: Off color questionPosted: 25 Apr 2010 at 10:49am |
Either the lift pump, or cup seals on the injection pump drive-shaft. The flex ring is likely broken apart, plugging the return, thus blowing the drive seals. HTH, Ed.
kyvfarmer
Joined: 08 Feb 2010 Location: Switzerland,Fl Points: 7 |
Posted: 25 Apr 2010 at 10:29am |
Hi guys
I have an old JD 4030 that I use few times inthe season ,I'ts been parked since October .Yesterday I went to crank it up and found when I pull the dipstick that the fuel have travel to the crankcase having 15 gallons of fuel plus the oil,what can be causing this? Thanks
