Off color question Ford 4000
AC 426 power View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Topic: Off color question Ford 4000
    Posted: 11 Feb 2022 at 11:37am
Wondering if anyone here has experience with a a ford 4000 three cylinder diesel, my problem is it runs very rough and if ran long enough will ultimately die, I have replaced the fuel filter, replaced all the rubber lines, made sure fuel is returning to tank and have cleaned the screen in the tank etc put in fresh fuel still won’t hardly run, when it does run it sounds like a flutter or miss and has no power or throttle response. I’m lost on this one, thinking it may be the CAV pump? Going to try and post a link to a YouTube video of it running to help out. Thanks! https://youtube.com/shorts/xCJoWRF4YOo?feature=share
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 12:14pm
It sounds like it is running on 2 cylinders  ???  Could be the pump or could be an injector problem ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 12:37pm
Definite miss-fire on 1-cylinder. No puffing exhaust smoke, so it has to be a lack of fuel delivery to that 1-cylinder. Pull all injectors and injection pump and have them gone thru. This assumes the starter is turning the engine over smoothly/evenly, indicating compression on all cylinders, which I think it is OK.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 1:14pm
Thanks, think I’ll do a compression tests just to check but yeah I think it’s fuel related
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 2:01pm
3 cyl CAV pumps do seem to eat the cam ring more often than 4 or 6 cyls. If it lost one lobe, it would lose the one cyl.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 2:11pm
I think this tractor is the Simms in-line ?? maybe not ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 5:40pm
All i've ever seen on a 4000 is the early 4 cylinder ones with a vertical Roosa DB, or the later 3 cylinder ones with a CAV DPA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 6:03pm
OK. I knew the 4-cylinder model 5000 and 7000 series were all Simms version, and assumed the 3-banger was too.  That Red-Tiger 4-banger with the Roosa Master pump was a reminder of how the D-19 deezel was built.....just a gas engine with a different cylinder head ......
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 6:07pm
forgot to mention that the problem has gradually gotten worse, with it running fine cold and then starting to miss as it got warmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 6:19pm
The 6X & 6Y tractors have the Simms pumps, with the 7A series the CAV pump began use. The 1964 and older 4 cylinder diesels have a Roosa Master pump
Edited by PaulB - 11 Feb 2022 at 6:20pm
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 9:36pm
we done a major overhaul on a 67 4000 with a 3cyl and m and w turbo last winter for a guy ran like that it had a cav pump it ran like that because it had been overheated bad from a hole in the radiator and just lost compression that turbo really gives it a good sound
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2022 at 11:39pm
What type of fuel filter ? IF it is the CAV type there are 2 different filters  one correct one not  - IF it is the type that takes the element with the holes in the top - the other filter will fit but the square oring can compress down in the top edges and block the fuel flow.  I was given the NAPA line to call about issues like this and was told by a NAPA guy "we sell more filters than anyone in the world - we don't need your input!"  We had over 20 tractors in the shop with wrong Napa filter issues in the CAV system.   Just my 2 cents applicable or not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2022 at 11:13am
Those filter seals are incorrectly installed by the owners.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2022 at 11:57am
Plus 1 on that!, we were seeing that 25 years ago when I was still working at a Ford dealer
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
JohnColo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnColo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2022 at 12:47pm
I'm sure you checked, but is the air cleaner filter plugged?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2022 at 7:01pm
if theres a prob. with the napa filters then the seals were were installed wrong
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC 426 power Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2022 at 7:37pm
Yes I did check it all was good
albatros_3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 1:00pm
My Ford 3600 and a friends Massey 2135 both had this issue. It was the CAV pump. Ford owners manual says to have the injectors done every 1200 hours as well. It’s pricey, but I’d have the pump rebuilt and injectors tested and clean the whole fuel system. I run my stuff over to Superior Injection in Detroit and everything is ready the next day.
Tom59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom59 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 1:22pm
I get all my fuel filters from my dealership, in the past they been the same price or cheaper than auto parts stores. My Massey Ferguson tractors have CAV pumps on them so I guess I eliminate that problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2022 at 2:50pm
Those are nice tractors !
