Off color need help with ID of tractor |
Jeeper38 ![]() Silver Level ![]() Joined: 18 Jul 2011 Location: Mo Points: 140 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Apr 2016 at 8:24am |
Working on getting this Massey going for my neighbor. Not sure of year or model. Anybody recognize this?
DougS ![]() Orange Level ![]() ![]() Joined: 03 Nov 2011 Location: Iowa Points: 2490 |
It looks like a MF 35. What does the name plate say? No year can be determined without knowing the serial number.
Found the ID plate right in front of the steering wheel. lol. I was looking all over and it right in front of me. It's a TO35. Got it to start. Needs some TLC but should run good for him when done.
Eddie ![]() Silver Level ![]() ![]() Joined: 25 Nov 2010 Location: North Alabama Points: 117 |
3 speed or 4 speed transmission?
Allis Chalmers 6060
10' Howse Rotary Cutter 5' Tiller 5' Box Blade 4' Aerator Ferris Zero Turn Mower W/10' fold up sprayer John Deere 455 Lawn Tractor John Deere 955 w/loader & 60" belly mower |
3 Spd i believe with a hi-lo selector to the side |
Bill_MN ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Hi/low is likely a Sherman overdrive, a common aftermarket item on these tractors
the hi-lo selector goes down in to the main gearbox. it's not off to the side or anything. I think it looks original but i know nothing about them. This is my first run in with a massey ferguson
If I remember correctly 3 speed would be pre 49. I'm sure someone will correct me if I'm wrong.
Allis Chalmers 6060
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2269 |
My wife's cousin has one like that.....mid-fifties......note "spin-out" wheels.
Has factory Hi-Lo range. Also has a 2 stage clutch for live PTO. I don't think all of them had that feature, tho. This is about the time of the transition between Ferguson and Massey-Harris. If I recall correctly the I.D. plate may even say Massey-Harris-Ferguson or something like that. Great tractor!
JoeM(GA) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Cumming,GA Points: 4846 |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
I have one step up from Joe's 135, a 79 230 wit 3 cylinder Perkins
Dang Charlie, that thing ever been outside?
Nice tractor! |
It has now
Here's a pic of the selectors. Any ideas?
Looks just about the same as my 230. 3 speed and reverse on the left and low, neutral, high on the right (short shifter).
Tractordata.com lists 3 different TO35's from 1958 to 1964 and all 3 show a tranny with 6 forward and 2 reverse. Edited by CTuckerNWIL - 13 Apr 2016 at 6:49am |
Nat ![]() Bronze Level ![]() Joined: 22 Sep 2009 Location: Lexington NC Points: 141 |
It's a to -35 ferguson. There is a difference in a MF-35 but it is the prerunner. Could have been Ferguson Grey, could have been a green belly or could have been red with Grey frame |
Nat
Ferguson TO-35 - transmission 6 forward and 2 reverse. |
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
There was a time period when those tractors changed color from the factory every year seems like. There was a wide variation in color when they were featured at a large show like Mt. Pleasant one year.
I don't know when they started offering diesels but they tended to use 3 cylinder Perkins for a long time. Gas engines in that size tractor changed from four cylinder Continental (the early MF-135 was offered with two sizes of gas engines) to three cylinder Perkins gas. My '68 MF-135 was the last year for the Continental. Gerald J. |
BrianC ![]() Orange Level Access ![]() Joined: 16 Jun 2011 Location: New York Points: 1619 |
I saw a MF 135 mystery machine at Tulare CA 2013 show. It was very, nice. But it looked more like a 165 with a 3 cylinder Perkins. I thought nice machine, but someone made a real Frankenstein there, "parts is parts" I guess. I just figured out last week it was the orchard model. Standard 135 has outboard drum brakes. The orchard model gets the 165 style drive train- inboard disk brakes, outboard planetary final reduction drives, straight front axle and hydrostatic steering system. Really different. How did they justify keeping the same model number, English way I guess. That bugged me for three years, now solved.
Take at look at the orchard model differences shown in AGCO's online parts books. They did this to the 135,235,240 and 245 that I know of. Not the 230. |
In the late 60s MF135 were made in Canada, England, France, Germany, South Africa and probably India and at least one middle eastern country. I have a book about the 100 series. Based on the specification in that book the only thing for sure shared between the different factories was the paint color and model number. I know the North American model like I have came in standard or special and deluxe with different Continental gas engines plus the three cylinder Perkins diesel. The next year, 1969 they went to a three cylinder Perkins gas. The deluxe came with at least two, probably 3 different transmission options and a couple PTO options. Mine has 12 speeds foward with two shifters and an imitation IH Torque Amplifier to split the gears with a hydraulically shifted gear splitter, the only shift that works on the go. Mine has a differential lock that wasn't on every one and a factory hydraulic valve that with three levers runs or locks the three point and runs two remote outlet pairs. The levers beside the seat still set the three point position and the pump operation when the three point isn't locked. They have to be at the top positions to use the remotes.
The English MF-135 used the same engines IIRC but drastically different power steering. Many MF-135 parts were shared with their MF-148. So much that the service manual from England covers the 135 and the 148. But the copy I bought on epay has nothing like my MF-135 other than the model number. Nothing else matches. The French and German MF-135 used different transmissions and engines and tire sizes. The other factories used locally made engines and drive trains. So there's no surprise of how many variations the orchard model showed. About 20 years ago I called the MF design center around Kansas City and asked about the strength of the front axle. I was connected to an engineer who told me the current 235 model used the same axle and he knew the load rating for that axle. My front axle has been broken and welded, before I got the tractor. It came with a 236 loader that is too big for the tractor, it was used up to MF-274 with 70 hp and front wheel assist. Its on my JD4020 now and is sturdy enough the 4020 hasn't broken it. Gerald J. |
