Off Color Massey 36 Hay Rake - Woven Bushings? |
wjohn ![]() Orange Level ![]() ![]() Joined: 19 Jan 2010 Location: KS Points: 2245 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Apr 2025 at 10:52pm |
I am taking a $50 Massey-Harris Ferguson 36 hay rake that was destined for scrap and dumping too much time and money into it. I have heard these were decent rakes and this one is a 6 bar to boot. One of the main things it needs is attention to the axle shaft bushings to the main frame. There was a lot of play, some of which is from wear on the shaft and some is from wear in the bushings.
I have never seen bushings like these before. They have a metal casing (which is worn very oblong) much like the original oil seals common on our tractors, which is pressed into the hub casting. The bushing material inside that casing is some kind of woven... nylon, cotton, or something similar. It reminds me of the webbing around gas tank mounting on some of these old tractors, except much thicker. At first I thought it was a farmer fix until I found a picture of a NOS bushing on eBay that has this exact design (recently sold). Anyone seen bushings like this before? Any ideas for replacement material I could cut and put in there? Or, would you just remove them completely and replace with an Oilite bushing or similar? There is a grease zerk to lubricate them. ![]() ![]() |
tom51 ![]() Bronze Level Access ![]() ![]() Joined: 04 Apr 2019 Location: USA Points: 63 |
Packing for a slurred pump
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3093 |
Can't think of the name but its Poly something sort of like a plastic material that bushings were made of for the Besser Block machine we ran to replace the original bronze bushings that needed to be greased.The poly bushings were not greased and would outlast the bronze bushings greased.Check with McMaster Carr they probably have some that'd work.
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8730 |
Google sewage pump gland packing. It’s a graphite rope.
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5143 |
for what you are starting with, how about finding PVC pipe that will press into the hub? It might need a piece inside of a piece to take up the clearance, but it would be cheap to see how it works.
Les Kerf ![]() Orange Level ![]() Joined: 08 May 2020 Location: Idaho Points: 1343 |
Maybe try wooden bushings? I have al OLD field disc that uses maple bearings (bushings).
Thanks for all of the ideas and sorry I never followed up with this thread. I got buried getting the combine ready in time for wheat harvest, and then the weeds were so bad that I didn't bother baling any straw. The rake got shoved to the side, but not before I wound up locating some NOS axle support castings that had new bushings in them. I need to put it back together at some point.
Tracy Martin TN ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10823 |
Delrin AR is what you want. Tracy
ecosse23 ![]() Bronze Level ![]() ![]() Joined: 12 Mar 2024 Location: Scotland Points: 34 |
Is Delrin the trade name for acetal? I have in my mind the pale coloured thermosetting plastic that gears and bushings are sometimes made from, think it’s tricky to machine. |
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 634 |
Its not hard to machine at all. Ive turned it bored it and tapped it
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
I’m maybe thinking of another plastic called Tufnol?? Definitely remember having to be careful about the type of drill bit and limiting the temperature the plastic reached while working on it.
