off color JD 240 engine rebuild
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Topic: off color JD 240 engine rebuild
    Posted: 16 Jun 2014 at 6:23pm
While mowing Saturday my little JD developed a bad rattle noise. On inspection I found the shaft for the counterweight had come loose. I tightened the nuts and restarted, engine runs OK but has a light noise. A assume the bushing on the counterweight has to be messed up. The question is are these Kawasaki fc420v rebuildable at a reasonable price? Looking at the JD sight it seems some of the parts are NLA and a quick internet search didn't do much better
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2014 at 8:31pm
John Deere discontinued counter weight and bushing so probably screwed.
