Off color information |
Bill Long
Joined: 12 Sep 2009 Location: Bel Air, MD Points: 4556 |
Topic: Off color informationPosted: 21 Oct 2016 at 8:40pm |
Ladies and Gentlemen, My son has obtained a John Deere 70 lawn tractor. It is a tractor his cousin used on his place and he always LOVED to sit on it. They sold the house and he was delighted to get it. He has had it running and it has been housed inside all the time.
Steve is looking for the best place to purchase replacement parts. I know John Deere is still in business and guess they would have parts available. Anybody else?? Sometimes you all know exactly where to go. Thanks in advance. Good Luck! Bill Long
Josh(NE)
Posted: 21 Oct 2016 at 10:45pm |
Bill I have had good luck with Allis and farmall parts I have ordered from Steiner. Hope this helps.
http://www.steinertractor.com Also thanks for all your contribution to the forum, your experiences shared here have helped make the forum a great place to hang out. |
Allis Express
'65 190XT, 37 B, '72 170, '83 8030, and the IH 560 was a mistake |
Josh(NE)
Posted: 21 Oct 2016 at 10:50pm |
Sorry I missed that it is a lawn tractor, that makes things a lot tougher.
Allis Express
alleyyooper
Posted: 22 Oct 2016 at 7:35am |
Lots of places to buy lawn and garden tractor parts even for the green ones.
Just use Google. Jacks small engines has parts as does parts tree. http://www.repairclinic.com/Shop-For-Parts/a21b314d1133528/Model-70-John-Deere-Replacement-Part-Lawn-Mower-Parts Made 1970 - 1974 Engine 7HP Tecumseh 245cc 1-cyl gasoline 70 serial number list. 1970: 25001 1971: 35001 1972: 45001 1973: 50001 1974: 56001 Final: 58292 Al
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 22 Oct 2016 at 9:21am |
That motor will probably be the tuff part. I had a Bolens with a 12 hp Tecumseh that I ended up giving up on because I couldn't get parts to fix it. That one will require some serious Google time or maybe a repower if it is bad enough.
Ted J
Joined: 05 Jul 2010 Location: La Crosse, WI Points: 18943 |
Posted: 22 Oct 2016 at 4:38pm |
Granted it was a cousins, but jeeze Bill......... Can't he get a "B" to cut grass with?
![]() I expect that he will have to spend some computer time searching for the parts he will need. Not a hard thing, just takes a lot of time. Good Luck ole Buddy! Ted J |
Tcmtech
Posted: 22 Oct 2016 at 4:46pm |
I picked up a JD 112 garden tractor earlier this summer that needed some basic fixing.
Surprisingly there are a lot of online markets that carry parts for those older units so I suspect that your 70 fits into a similar popularity niche so you may very well have the majority of the parts availble as good used ore OEM replica available. Ours did even with 10 HP cast iron Tecumseh engine with the odd ball two brush starter! Head gasket and starter brush kit was less than $50 to get it running.
Gerald J.
Posted: 22 Oct 2016 at 7:03pm |
I have a '68 JD 112. Its Tecumseh threw the rod. JD had rod and oversized piston and rings for a rebuild. I don't know if the crankshaft survived and the block needed boring because the cylinder was barrel shaped. I found a recoil starter Briggs from the store in Kansas City delivered for less than the parts from Deere. I had to drill a couple new mounting holes and make a shaft adapter for the pulley. I can't put the grill or hood back on but it mowed for several years. I kept the remains of the Tecumseh in case it wants to be restored to the original.
10 hp on the shallow 47" deck didn't mow the 1.5+ acres at the new place very well, My dad's old 30" Snapper Comet mowed better, and my Snapper 250Z with 20 hp on a 42" deck does pretty good though sometimes I spend more time under it than on it. Gerald J. |
shameless (ne)
Joined: 08 Jul 2016 Location: nebraska Points: 7463 |
Posted: 22 Oct 2016 at 7:07pm |
I think that little garden tractor came out with a Kohler motor Bill....
Bill Long
Posted: 22 Oct 2016 at 8:05pm |
Gentlemen, Thank you all so much for your information.
I know my son will be delighted with the input. Good Luck! Bill Long
alleyyooper
Posted: 23 Oct 2016 at 3:59am |
Went to tractor data dot come and they list the engine as a 7hp Tecumseh.
A good replacement engine would be a HF 212cc 6.5 hp engine. http://www.harborfreight.com/engines-generators/gas-engines/65-hp-212cc-ohv-horizontal-shaft-gas-engine-epa-69730.html Real life they are probably closer to 8hp. AlEdited by alleyyooper - 23 Oct 2016 at 4:01am |
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3092 |
Posted: 23 Oct 2016 at 5:56am |
mytractor forum has a bunch of JD guys that can probably help you out also if you send me a PM I'll give you the name/number of a friend of mine near me that has a huge JD L&G collection and a bunch of parts L&G tractors.
