off color help needed
EClark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EClark Quote  Post ReplyReply Direct Link To This Post Topic: off color help needed
    Posted: 07 May 2012 at 8:39pm
got a friend that has a M.M. u that is overheating. had it out here tonight and at 3/4 throttle it over heated in about 10 min.any ideas?
thanks Eric
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 9:03pm
Give up a little more info. Has it had antifreeze in it for a long period of time. My B had been drained and that is the worst way to store a coolant system over winter. I ran some NAPA rad flush through it last year and got a little red out after running up to temp a couple times. I then ran it up to temp with a mix of water and Arm and Hammer washing soda and got a little more crud out. This spring I put a gallon of vinegar and a gallon of water in it, mowed for about an hour and drained it. It looked like orange tomato soup coming out and was pretty thick and chunky. I refilled with vinegar and water and will mow a couple more times and then drain and flush.
 You could have crud in the system, a stuck thermostat, or a bad water pump.
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2012 at 11:52pm
check the thermostat while you are at it, dont sound like its opening up completely
i like old tractors of all colors
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 7:29am
Take the radiator cap off before you start it, as it warms up see if coolant is flowing. If not the thermostat isn't opening or the water pump isn't pumping.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote EClark Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2012 at 5:46pm
that's what I'm getting ready to do tonight.was just wondering if there was anything that was a common cooling problem on a M.M.  U ?
Eric
This page was generated in 0.069 seconds.
