Off color help needed
Message Reverse Sort Order
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Topic: Off color help needed
    Posted: 23 Feb 2019 at 4:26pm
Les, about three years ago, I emptied out a storage shed that I was tearing down to make room for new construction... it was my accumulation of many years of being around Cub Cadets.  I loaded up a heavy trailer load of IHCC parts, including a half-dozen decks, and took them to Marlin Homrighausen, in Colo, who distributed them out to people who needed parts.  I don't recall if there was a complete CCO deck in there, but good chance there were parts in the boxes... and an excellent chance that if you need a CCO part, if he doesn't have one, he knows which one of the Cub guys DOES.
As for the front wheel bushings, press the old one out, take it to a bearing shop, and have 'em look up the proper ID, get 'em an inch longer than you need, then send 'em to me with one of your wheels, I'll cut the OD for you.  ;-)
JoeO(C-MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(C-MO) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2019 at 10:15am
Les, try this link;
HTH
Click on the "CCSpecialties" box, go down to 'mower deck parts', look for new and a used LH cogged pulley, be seated when you find them.   There was a RH pulley listed on another page but has been sold.  I will keep looking to better the link.
Edited by JoeO(C-MO) - 23 Feb 2019 at 10:33am
D10 III, D15 II 3 pt, D15 II SC, 170 Gas w/shuttle, 175 Diesel UI ROPS, 185 w ROPS. AC 653 w/6 way blade, ROPS
AC 615 Ind. WD45 running/Parts.
Les Royer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2019 at 2:12pm
Tracy, this cub was produced before they assigned any model numbers. International Harvester started cranking out these lawn tractors in 1961.  And they simply called them cub cadets. It wasn't until the introduction of the model 70 in 1963 was there ever a model number issued to define the tractor. Common talk then refered to the older models without a model number as a cub cadet"Original."
These Original tractors can be a pain if you have an early model. Mine is a 62 and it's in that early group. A lot of the parts are different and no longer produced, making them hard to find.  For example my front wheel bearings are shot and you wouldn't think that's a big deal. However, this tractor doesn't have bearings but bushings. And there isn't a bearing replacement nor do they still make the bushings. Only choice is to butcher up the spindles to make the 7/8 shaft a smaller 3/4 to accommodate a bearing. Same goes for the front axle pivot pin. Nope, can't buy one so one has to be machined. I don't have a lathe, so I have to pay to have one custom made.
What I need is a couple of mower deck pulleys. These are splined pulleys that uses a cog belt. The blades have to be timed so they don't hit each other.  They hadn't learned to stagger the blades yet. They can be found on any early 2 blade 38 inch deck.
I still gots my A/C but it's clear out in the barn now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 7:30pm
Les, what model number? What parts? I might can help.  Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 5:29pm
Les,
OCC Only Cub Cadets is a pretty good source and forum.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Royer Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2019 at 3:57pm
Hey, if anybody has an old International cub cadet "Original" lawn tractor laying about, let me know. I'm looking for a few pieces.
Thanks Les
