Off color, Ford 8000s? |
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2307 |
Topic: Off color, Ford 8000s?Posted: 15 Apr 2018 at 9:11am |
Does anyone know if this series was known for weak pto clutches? I have looked at 3 that said the pto was weak, not sure what they meant?
Posted: 15 Apr 2018 at 9:22am |
Yup, and I think the tractor has to be split under the platform to repair it.
Jordan(OH)
Joined: 11 Sep 2009 Location: Celina, OH Points: 1568 |
Posted: 15 Apr 2018 at 2:44pm |
Put many thousand hours on ours blowing silage, running big manure spreader, cutting and baling hay with no clutch trouble. The brake can cause trouble if shut off at high speed.
HD6GTOM
Posted: 15 Apr 2018 at 5:52pm |
Do the brakes work? Its been 30+ years since I was around them. If memory is right--the wet brakes go out, everything in the tranny, rear end, hyd system is effected. Somebody correct me if this is not right.
shameless dude
Posted: 15 Apr 2018 at 7:01pm |
brakes? who needs brakes?
Jordan(OH)
Posted: 16 Apr 2018 at 2:25pm |
I'm referring to PTO brake.
HD6GTOM
Posted: 16 Apr 2018 at 9:32pm |
Jordan - yes I know and you are right about the PTO brake. I am communicating about the foot brakes. If I "remember" right they are built inside the rear end housing. When they go bad the worn linings take out everything inside the housing. The older I get, the worse the memory gets. I do know it happened to FIL's. Like I said-- if this is not right someone else please respond.
Jordan(OH)
Posted: 17 Apr 2018 at 4:45am |
Show me a tractor with hydraulic brakes not inside the rear housing.
They require hydraulic brake OIL, if one uses regular brake fluid and it leaks in contaminating the system then yes, bad things happen. |
