off color but What the????
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Topic: off color but What the????
    Posted: 28 Dec 2010 at 5:25pm
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 5:28pm
they claim it runs and steers with the breaks to a degree.
German Shepherd dad
#WD234847
#WD88193
Chris(WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris(WA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 5:28pm
The great Push-me-pull-you! Looks like two worlds collided! What will someone think of next? Joined at the rear axle facing different directions?
Washingtonian by choice, Wisconsin Farmboy by the grace of God!
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 5:45pm
Siamese Deere. Better put it out of it's misery.
Wink
I am a Russian Bot
split51 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote split51 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 6:38pm
 I am not much of a Deere fan but it looks like a waste of two decent tractors to me.
1929 20-35 sn17662
B1 w/snow blade
B10 w/sickle mower
B110 w/mower deck
B110 w/tiller
B112 w/grader blade
B210 w/plo
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 6:43pm
It looks like they finally figured out that 4 cylinders is better than 2. They might finally have enough power to get some work done.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 6:59pm
articulate it in the middle and you might just have something...
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 9:40pm
they never did know if they were coming or going!!
Pa.Pete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pa.Pete Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 10:13pm
Now that's funny!  All I can say is why?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 10:26pm
I think its photoshopped. The tires are in opposite directions so one will pull better than the other. Then if the transmissions are normal, reverse in one might come close to 1st gear in the other, but there's no way to match up the gears. There's not the possibility of flipping the differential ring gear to the other side, there's no right angle drive in the JD of that design.
Then the two radiators that close won't get good air either.
Gerald J.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 11:14pm
I'd guess photoshop. It would take a lot of time and money for something so pointless and I... Hey wait a minute that sounds a lot like... OH nevermind, as I think about it, it's probably not photoshopped after all. LOL!
Edited by Dave in il - 28 Dec 2010 at 11:51pm
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 12:13am
I guess it could be done....but it wouldn't be worth anything really. if you can't turn you can't take it to shows. At our show, a local john deere whiz and an allis guy put a deere and allis together. One was John Chalmers and the other was Allis Deere. Not sure if I've seen them there the last couple of years though. If they're there this year I'll take a picture.
Allis Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fields Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 6:16am
 Wow a bonus buck... I shoot the one the DNR will give me a tag for the other one, Since there antlers are locked up so tight.
  Acualy someone around here did that this year. taged a buck with a bow licence draging a dead horn locked buck. Too bad he used a GUN to shoot it ON THE ROAD. And then braged about it. the Dnr came out looked at them and fined him.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 6:29am
Paddle faster . . . . :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 9:52am
On RFD they had a show where a John Deere and a Farmall were split in half and joined.They called it "Half Right".When they were done they still had the other 2 halfs so they joined them and call that one "Half Wrong".Basically a waste of 2 tractors ,but they were not A/C so who cares.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 9:56am
One muffler, one air cleaner, and steering rod is straight across, no hookup to it for anything. Frame rail straight across, no articulation joint. Unsure of  right side machine is a runner as looks like not set up with working engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 10:28am
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 10:33am
It's just yard art.  Non-functional yard art.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
jminpa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jminpa Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 10:44am
There is an air cleaner and a muffler on each of them you can just make them out in the picture as they are straight across from  the other
This page was generated in 0.069 seconds.
