Off brand pto???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Topic: Off brand pto???
    Posted: 05 Sep 2021 at 12:09pm
Hello
Have a older woods batwing brush hog. On the the carrier bearing of the pto shaft. It has the two upright straps going up off the hitch, the carrier bearing has a single pin go through it and appears like it should swing free in there on that pin. And there’s other holes in straps to allow you to adjust hight of pto, then on top there’s a bolt with spacer. The way it is now the carrier bearing is pinched in the straps. But there’s some repairs on the hitch and straps so it is possible that that changed things. It would just take a washer in with spacer to allow it to swing in that pin.
Just figured I’d see your thoughts. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2021 at 12:28pm
looks something like this ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2021 at 1:21pm
Mike, it should be free to move. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2021 at 2:06pm
yup. Thanks
