Odd Hybrid JD-Farmall tractor - in PA auction |
KMAG
Joined: 26 May 2020 Location: Elizabethtown, Points: 690 |
Topic: Odd Hybrid JD-Farmall tractor - in PA auctionPosted: 03 Mar 2026 at 5:43am |
Saw this oddity while looking at auctions. Guy connected a JD and Farmall tractors.
I would be concerned about welds at final drive as I thought the metal was iron, not cast steel and steering being consistent/tracking together. ![]() ![]() ![]() Edited by KMAG - 03 Mar 2026 at 5:46am |
Posted: 03 Mar 2026 at 6:20am |
What a STOOPID project !!!
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4284 |
Posted: 03 Mar 2026 at 6:28am |
A classic case of someone that has too much time on their hands!!! My question to things like this is; If you have the ability to build something like this, and it actually works, why not do something constructive?! John Kinzenbaw never built a pos like that.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3133 |
Posted: 03 Mar 2026 at 8:03am |
They had an argument wiht the hired hands, one wouldn't drive a farmall, the other wouldn't drive a deere. Now when it's work time they pick which one they want to drive.
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3200 |
Posted: 03 Mar 2026 at 8:05am |
Hey guys remember the time during the big snow storm we were all down at the shop smoking weed?
KMAG
Posted: 03 Mar 2026 at 8:08am |
Are there 2 sets of cracks near the Farmall final drive flange or are they casting lines?
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25272 |
Posted: 03 Mar 2026 at 8:21am |
something I'd expected to see on the Red Green Show, decades ago.....
Kcgrain
Joined: 24 Sep 2009 Location: Wisconsin Points: 811 |
Posted: 03 Mar 2026 at 8:47am |
he thought if he put them together he might get as much work done as 1 WD45
KMAG
Posted: 03 Mar 2026 at 9:45am |
It would need a whole lot of duct tape to qualify.... |
Posted: 03 Mar 2026 at 10:06am |
One thing for sure with two WD-45's is, if you put them both in the same GEAR, they would go the same speed if engines were synch'd RPM wise. That Red/Green combo is engineeringly dumb.
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 261 |
Posted: 03 Mar 2026 at 11:25am |
Now Doc how do you know he don't have the PCM all tricked up on that contraption ??? Dave
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 170 |
Posted: 03 Mar 2026 at 11:32am |
If I remember right there was an article on this tractor in one of the farm magazines thirty-some years ago. I think the speed issue was one of the big things to overcome.
And since no one else has made the comment - what else would you do with a JD and a Farmall? Ted |
ToddnwIl
Posted: 03 Mar 2026 at 12:10pm |
I think this falls into the category... just because you can... doesn't mean you should!
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55299 |
Posted: 03 Mar 2026 at 4:11pm |
If the JD's (or the IH's)diff is welded, then the speed thing isn't much of a problem...
TedN
Posted: 03 Mar 2026 at 5:04pm |
Did some searching and found the article. Farm Show magazine, Vol. 30, no. 4. Reading it he didn't figure out how to overcome the speed issue, he could run it from one tractor or the other. So probably locked differentials in both. This also wasn't the first time he put two tractors together, just the first time they were different tractors.
https://share.google/2nOFfC88y7v2iVCbm Ted Edited by TedN - 03 Mar 2026 at 5:07pm |
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 03 Mar 2026 at 6:55pm |
if the wemon dont find you handsome at least they will find handy
Joined: 11 Sep 2009 Location: illinois Points: 90871 |
Posted: 03 Mar 2026 at 8:18pm |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5477 |
Posted: 03 Mar 2026 at 9:17pm |
What a waste of time and money IMO.
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4942 |
Posted: 04 Mar 2026 at 5:15am |
look at the bright side, they didn’t waste a old Allis doing that!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 582 |
Posted: 05 Mar 2026 at 8:37am |
Joe, good point. He did waste a good green one & a red one. There are many more out there. Makes for conversation but not useful for anything but that.
Nathan (SD)
Joined: 11 Sep 2009 Location: Day County SD Points: 1304 |
Posted: 05 Mar 2026 at 9:31am |
![]() Somebody just posted one a few months ago |
IBWD MIke
Posted: 06 Mar 2026 at 6:51am |
Why?
Posted: 06 Mar 2026 at 7:27am |
I find that far more intriguing than the Red/Green show. I'll bet you could actually plow or disc with that unit !! Be interesting to see how those rear ends bolt together where those six final drive studs are.
Posted: 06 Mar 2026 at 9:28am |
the Allis looks a lot better and more compact... Working on the distributor and carb in the middle could be a challenge.
AllisFreak MN
Joined: 07 Dec 2009 Location: Minnesota Points: 1619 |
Posted: 06 Mar 2026 at 9:05pm |
Prolly better make sure you have both transmissions in the same gear? And where did the hand clutch('s) go??
Edited by AllisFreak MN - 06 Mar 2026 at 9:07pm |
