Odd D17 question
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 10:01am
Mount a hand start pony engine to the belt pulley
$100. 5 HP motor from harbor freight would be a cheap drive... thru the PTO.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 10:29am
I had the same thought as Lon(MN)
Mount a small B & S Engine in front of the Tractor Side Belt Pulley.
Install a Clutch Pedal disengagement lock similar to a WD or WD-45.
To start D-17: Lock Clutch Pedal down, Engage Tractor Belt Pulley,
start B & S Engine. While sitting in Tractor Seat, release Foot Clutch Lock, then SLOWLY release Foot Clutch to start cranking Tractor Engine.
I wouldn't tie up the rear PTO just for the sake of starting the engine.
G
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 10:51am
I want to know what you are up to?
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2020 at 10:57am
Park it on a steep hill...
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 9:31am
No good  Wink
I have an interest in "off-grid" living.  Would like to be as independent as possible from
delicate civilized things like say, public utilities....and from complicated modern stuff...
Doesnt mean I want to live like that, but be ABLE to live like that...for instance I use electricity to pump water from my well, but I want to put in a hand pump to fill the tank and pressurize the line manually.....if my generator gave out.  I got NG from my well, so my NG would be off grid- so my cooking and water heat is off grid.
Not having to depend on batteries is a part of that.
That kind of stuff...  I just always found the self sufficiency topic interesting and never felt good having to depend  on the grid.
Edited by TomYaz - 28 Dec 2020 at 9:32am
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 9:57am
If all of this is to produce electricity by running a generator with a tractor so you can be independent from the electric company.  It would be a lot easier to get a whole house generator that runs on NG.  Or make a NG one yourself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 10:07am
I would want one of those too...I got a little brick milkhouse next to the house....
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 1:15pm
Not sure how removing the battery gets you off-grid, but have you considered a small solar panel to keep the battery topped up?
https://www.harborfreight.com/15-watt-solar-battery-charger-62449.html
Diesel is best for needing no electricity to run, but it would sure hurt to hand crank a large one.
Edited by Coke - 28 Dec 2020 at 1:17pm
1957 D17 Diesel w/ M&W Pistons
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 1:48pm
"off-grid" to me means having to depend on "outside resources" as little as possible.  A battery is a consumable made on the outside.  Solar no use when battery goes bad.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 3:02pm
The 226 engine was used as a power unit as well and those power units had mags and hand cranks so if you can make the hole in the bolster accept the hand crank then it shouldn’t be hard to do what you want to do
I can look in my parts books when I get a chance and see what’s needed
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 3:25pm
But as a power unit was the engine at the higher compression as the D17 version was?
When I look at my D17 grill there is a cut out for the hand crank to be inserted and the pully does seem to be shaped in a way to catch the crank end...but the  guys here are saying there is something else needed I dont have...
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 6:23pm
Dr. Allis
Is the D-17 Engine a W Model (WD-45) or a G Model (D-14, D-15)
Would a front crankshaft pulley from a WD-45 fit a D-17?
G
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 9:44pm
Tom, I know EXACTLY where you're goin'... and I'm that way myself.  There's a difference between being dependant, and being able to enjoy the comfort of a certain modicum of independence.  There is absolutely NO reason why anyone can justify snubbing another's pursuit of rugged individualism.  My reason is simply location:  My property's location is susceptible to outages, which usually happen under the worst weather circumstances.
My D17 is a series 1, and it HAD a crank-capable front pulley, and there IS a hole going through the bolster, as I removed said pulley, and utilized said hole for my live-hydraulic pump.
I don't see the compression ratio being significant enough to preclude hand cranking, particularly with a hot magneto.  I've cranked over things that were a lot more beastly.
My 17 has a power steering pump, and off the top of my head, I don't know if that, or the distributor drive setup, would conflict with putting on a magneto.
My largest backup generator has a Hercules JXLD 338ci inline six, with a magneto, and a propane mixer.  It will start, run, and generate just fine with NO battery required.  Of course, it still has an electric starter, and a distributor... it will crank and run off of either, and will recharge it's battery once started.  I've never HAD to crank it by hand, but I do... usually, I just step on the crank, as one step will push it past TDC, and after three pushes, it's got a live charge in a cylinder, and the moment the impulser clacks, off it goes.
In the circumstance of emergency/standby power, diesel fuel is certainly better in long-term storage than gasoline, but there is no comparison to the storage life of propane.  My generators are fed by a pair of 1000-gallon tanks on the back of the property.  A nasty ice-storm could knock down our lines for a week, and we do just fine.
If you REALLY wanna get your fuel-value out of it, plumb the engine's cooling system into a heat exchanger inside your house, and set up your furnace with a temp switch-  if the heat exchanger water is hot, disable the furnace's fuel valve (just run the blower)... that way the generator's waste-heat is directed into your house, rather than discarded to waste... and your furnace isn't burning fuel!!!
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2020 at 10:00pm
Standing on the crank or pushing down with your arm is NOT the safest way to crank an engine...one backfire and you break your leg or arm. Always pull upward with thumb and fingers on the outside!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 12:26am
Thank you for that hint of advice, but I built the starting pedal specifically for step-starting the Herc, as it's a generator, on a skid... too low to the generator-shed floor to kneel down on the floor and pull safely... but I assure you, the impulser is significantly PAST TDC, and the mechanism will NOT allow an unintended motion to come back into the pedal. Wink  My daughter could easily and safely step-start it when she was eleven.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 6:36am
Wow Dave, you are waaayyy ahead of me! Thankfully I dont have such weather issues.
I would intend to use the generator intermittingly for specific tasks. Basically want the ability to live like a Amishman if I NEED to.  But I wouldnt mind having a conventional whole house generator.
I'm really thinking my Super C is the correct platform.  Run it on propane for mobile work, run on NG for stationary work like power gen.  Get a fast hitch set of implements.
I dunno, just once again daydreaming....I got a 175 I need to get operational first...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 6:38am
Yet I see youtube videos saying to pull down.  I do like you explain it....Love the Super C for hand staring....often I can start it up cold with just one crank.
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 8:11am
That's an odd definition, but in the spirit of such, once you get the tractor going, doesn't the generator (alternator) make it self sustaining? Which would mean all you really need is a spark source to get it going whilst it cranks, couldn't you just put a capacitor where the battery is? That way you don't need to modify as much? And you have the bonus of still having an onboard power source for lights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 8:30am
Well call it what you will...does "goin Amish" sound better?
Best way to not be caught with a uncharged or defected battery is by not having one.
Sure does
I suppose, but where do I get my initial spark source?   Isnt that where the magneto comes in?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 9:00am
 I've got to add something that happened many many years ago.
 A guy had a WD-45 that was not turning over well with the starter, so he put a starter gear reduction adapter on it. It then kicked and broke the adapter.
 Then it was discovered that the advance/retard in the ignition was stuck on advance.
Dusty
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 1:33pm
Even a defective battery is probably good enough to provide an initial spark, if you are hand cranking the engine. And if you are self-sustaining, where are you getting your gasoline from? Surely that's a bigger consumable than a battery?
Sure does
The capacitor would get enough charge from the turning of the generator/alternator to provide your initial spark, or just leave an old battery in there, and hand crank either way.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 2:53pm
Tom
How much Tractor do you need ? Would a D-10 or D-12 suffice ?
The earlier D-10 and D-12's had a Rad Support similar to a B, C, and CA.
It had the proper cut-out for a Hand Crank. Prior to Series III
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2020 at 3:22pm
Originally posted by Gary Gary wrote:
Tom
G
I need something that will get me net 15HP at the PTO @ 540 RPM using NG/Propane. so about a tractor with 20% more HP? to make up for switch from gasoline??===20HP PTO?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2020 at 10:30pm
[QUOTE=Dusty MI]... A guy had a WD-45 that was not turning over well with the starter, so he put a starter gear reduction adapter on it. It then kicked and broke the adapter.
[QUOTE]
Which is EXACTLY WHY when Bosch patented the Impulse Coupling, it was such a success:
Not only did it provide a very rapid 'flip' to the magneto armature (generating a really hot spark at basically NO crankshaft speed), it also delayed the spark by almost 20 degrees.
A properly set up magneto, and properly timed engine, will absolutely never 'kick back'. If it does, it's because the magneto is not set up properly, or it's not properly timed.
if the magneto's impulser coupling is not retarding, it is not impulsing, either, because the 20 degree retard is how the impulser coupling's clock spring winds up in the first place.
Most people don't have a clue of the 'why' when they repeat the hand-crank warning, they have no concept of where that warning originated... those that do, are those that own, or have owned a Ford Model T, or a Ford Model A.  Why?  Because Henry did NOT see fit to install OTHER manufacturers' components on his products, nor did he take kindly to the concept of paying royalties on others' patents.  As a result, he deemed his ignition systems 'good enough', and for incidents where the Model T's buzzer coil, timer, and flywheel-magnet generator scheme, or the Model A's hand-op spark advance resulted in an injury, he identified it as 'operator error'.   I assure ANYONE who takes a hand to the crank of my '24 T or '29 A, that if they don't EXPLICITY follow the proper method of cranking, REGARDLESS of how they hold the crank, or address the pull, the engine WILL kick them, and break their forearm.  Period.
If you look at the incidence of hand-crank injuries for those starting engines with impulser couplings, particularly the Bosch-patent types used in American Bosch, Wico, Fairbanks-Morse, and others, you'll find that MOST of those injuries are due to the crankshaft bore and crank becoming bound, and not properly releasing from the crank, coming around in the FORWARD direction, and striking the individual who had already had the crank pulled from hand.  If they were injured by a kick-back, it was because they did not properly time the magneto.
Yaz-  Some people 'get it'... the rest, just don't.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2020 at 11:17pm
Hi Dave,
If I ever get to doing this....big "if" as I have more ideas then cash or time, I got to be sure to get a magneto edumacation from ya!  Lot of stuff you said went WOOOSHHH over the head due to my ignorance!  LOL
This page was generated in 0.336 seconds.
