OC Field Cultivator
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Topic: OC Field Cultivator
    Posted: 06 Sep 2022 at 2:35pm
The Case IH Vibra Shanks are a pretty good unit it seems that I hear.....right?  What y'all think?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 2:56pm
Just check shanks for side to side wear if they did a 1,000,000 acres otherwise good
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 5:10pm
Had one for a while, good machine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 6:55pm
I didn’t wiggle every shank on it, but the several that I grabbed were amazingly solid!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 7:23pm
I have a 14' Vibrashank I have used over 25 years.  Does a pretty nice job.  You can hear the spring snap back when it hits a stone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Sep 2022 at 9:18pm
I like my 4800. Put new shanks and bushings in it when I got it. Hasn't done THAT many acres and there's some wiggle. Kind of poor design but hey! Could about go through a mowed hay field and not plug....maybe a slight exaggeration but  it worked standing stalks and knee high weeds last spring ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2022 at 6:35am
Kind of a poor design, how so?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2022 at 2:25pm
Meaning that the bushing and shank both wear. Can replace bushings easily but you're putting it in a worn hole. I suppose the bushing wears more but still...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2022 at 2:29pm
Thank you Steve.
Gotta count my pennies and see what the guy has to have for it.  It's a 24 footer, asking $7000.
This page was generated in 0.313 seconds.
