O-C carburetor woes
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Topic: O-C carburetor woes
    Posted: 18 Dec 2025 at 10:23pm
Workin on a M/S TXS #67(IIRC) on a Moline U, I put in a new needle and seat,, set the float at 1/4" like the structions say,,well,, floods really bad..runs, but lotsa black smoke,gas running out of the ai cleaner inlet..
Well, change back to the 'old' needle an seat,it runs really good,no 'flood' kind of exhaust smoke, it even sounds better,, no gas running out,, but hafta run about 1/2 choke to run at hi idle....☹️ tell me not gettin enough fuel..I do have good flow with the bowl plug removed.
Jus venting mostly,, I'll figure it out...😡
The one on the rear of the trailer is the culprit..
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2025 at 10:30pm
Let us know what you come up with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 10:54am
yea,, I was venting,,, but ,, well,,,suggestions be welcome...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 12:49pm
if your running with the choke 1/2 on, then the main jet is plugged... need to pull out the jets, rod out the holes, blow out with air, etc..
this assumes the intake manifold gasket is not cracked and your sucking in excess air..
Edited by steve(ill) - Yesterday at 12:50pm
