O.T. IHC #8 plow
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Topic: O.T. IHC #8 plow
    Posted: 20 Nov 2010 at 11:50pm
I'm working on a couple #8 IHC Little Genius plows. I've got one on steel for my unstyled WC and one on rubber tires to pull with my styled WC.
I'm looking for new or good used moldboards and I need some of the handles for the levers that pull the wire / rod to release them. And I need a good rim for the tail wheel on the rubber tired plow.
Charles (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charles (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 8:24am
I don't think you will find new moldboards.  Most replace each plow with a super chief plow.  Just have 2 bolts per plow to deal with.  Parts are available for them.  They will bolt right up to the beams.  The tail wheel  fix is cut out the center and weld on a new rim.  Good place to search is the forum on www.RedPowerMagazine.com.   I got a lot of good info to fix my #8 there.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 8:38am
My dad had one in the late '40's. He put Oliver Rad-x moldboards on it, not sure how Oliver spelled it.
Dusty
JW in MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JW in MO Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 9:35am
Give this guy a call, if you can find a number on the moldboards it will help.
http://www.macknair.com/index.htm
ICTRCTR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ICTRCTR Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 6:55pm
   i have a 2 btm ih plow on rubber complete trip rope. $ 175 for plow se nebr.402 223 5339 thanks.
