O T fitch
ron nca View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ron nca Quote  Post ReplyReply Direct Link To This Post Topic: O T fitch
    Posted: 01 May 2012 at 9:26pm
Did a little barn snopping to day i had it off. What i found is a Fitch Four Drive a friend has it its all there but need some sheet metal redune not stuck it has a big old rear end under the front like an squdd the the third member goes in from the top.
 The lasted date we can find is 1913 trens says pat 1909 it has 3 foward we think with a drop box for the frount axle .it was maid in Big Rapids Michigan moter made  by
 Climay Tractor Clinton Iowa.  Does any know about this tractor thanks ron nca
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2012 at 11:45pm
With the Climax engine it should be a model 20-35.  A pretty rare tractor. do you have pics?  I would suggest you post this on the "Lugs and Cleats"  website as that is the best place for info on steel wheel tractors.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2012 at 7:08am
