Number of teeth on B or C starter Bendix
Allis Barn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Barn Quote  Post ReplyReply Direct Link To This Post Topic: Number of teeth on B or C starter Bendix
    Posted: 12 Feb 2023 at 4:02pm
I have a Delco starter bendix with 10 teeth and another with 14.  Is either one correct for a B or C? Was there a change in the starter for the B for different production years.
Thanks
Bob
Larry in NC View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2023 at 4:12pm
14
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2023 at 4:25pm
10 tooth might be a D10-14 starter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2023 at 7:30pm
The B,IB,C,CA used two Starters. Delco 1107043 & 1107096. Either will work in these models and both are 14 tooth drives.
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2023 at 8:32pm
D-14 has two versions
original 6 volt tractor(has brush cover band on starter ) had 10 ?
12 volt , no band , has 9
I may be wrong, well probably, still thinking about the corn field...
They have different ring gears !!! Yeah I found THAT out.....
I assume the different gears and ratios were cause the 12V spun faster ?
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2023 at 8:51pm
I got one that has 12-1/2... LOL
Edited by DaveKamp - 12 Feb 2023 at 8:52pm
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2023 at 10:59pm
And I have one with only 11-1/2, now I know where the other half went! Tongue
