NO-TILL COULTER THOUGHTS |
Post Reply |
Author | |||
FREEDGUY
Orange Level Access Joined: 15 Apr 2017 Location: South West Mich Points: 5391 |
Posted: 16 Apr 2019 at 9:12pm |
What is the concenceous pertaining to N/T coulters on any brand of planter? We run a 7000 JD consertil with them on it now(was purchased already on it and possibly from the factory?). We had to plant last spring in somewhat more "moist" soil conditions than we like to and in spots during fall harvest, I could still make out the unclosed "wave" outline of the coulter. I am contemplating removing them before planting this season regardless of soil dampness. We plant in min-til soil BTW. Thanks
Sponsored Links | |||
CTuckerNWIL
Orange Level Joined: 11 Sep 2009 Location: NW Illinois Points: 22807 |
I have a 2 row 7000 set up for food plots. Last year I plowed a patch and disced it, but when I planted, I went another 40 to 50 feet past the plowed ground. Corn came up great in the plowed ground, but probably only 1/3 of it made it in the no tilled sod. I'm pretty sure the seed didn't get covered.
JimWenigOH
Orange Level Joined: 12 Sep 2009 Location: NC Ohio Points: 1153 |
I don't use or need them on my White no-till planter. I plant into previous crop residue with cover crops. Need to make sure the openers are in good shape though. I also use row cleaners to move most of the residue aside in front of the openers.
cwhit
Orange Level Joined: 12 Sep 2009 Location: Sigel IL Points: 963 |
We have a 12/23 Kinze and removed all of them. Don’t no till much but where we do doesn’t bother it at all.
Orange Level Access Joined: 12 Sep 2009 Points: 19473 |
There are at least three different types of NoTill coulters. Two inch wave.....one inch wave.....and one inch bubble. All of them are NOT high speed attachments, because they tend to throw dirt out from the seed trench. Speeds need to be kept somewhat down, like less than 4 mph.. The wider the coulter, the worse the problem. The wetter the soil, the worse the problem. The one inch bubble is my preference because it cuts thru trash better and has the least amount of soil throwing.
Tbone95
Orange Level Access Joined: 31 Aug 2012 Location: Michigan Points: 11388 |
Well said. Planting is no place to be setting speed records. The only thing I would add, is make sure you have good closing wheels too.
tomstractorsandtoys
Orange Level Access Joined: 11 Feb 2015 Location: wi Points: 515 |
You are either planting way to wet which will cause the seed trench to open up as the soil dries out or you need different closing wheels or need more pressure on the closing wheels. I have heard of people no tilling without the coulters and doing a good job. Tom
Allis dave
Orange Level Joined: 10 May 2012 Location: Northern IN Points: 2847 |
You need the coulters or row cleaners on there if you're no tilling. The opener will have a tough time cutting through corn stalks or wads of bean residue.
FREEDGUY
We have the row cleaners( my fault for not specifying) and in my original post(don't know if you read it) we are min-til. We normally don't plant into such damp soil but maybe some of you don't recall the planting conditions 340 days ago?? Thanks for the replies though.
Allis dave
I'm not sure what you meant by min-til. I'd guess that means you run a vt over it a couple times?
I know what you mean about the wet ground! The Kinziw with ripple coulters I drive for beans is the same as a 7000. I don't remember the coulter waves in the ground, but I have trouble getting the trench to close sometimes.
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3195 |
For no-till or any other planting practices, REMOVE NO-TILL COULTERS.
Yes, residue managers help remove potential hair pinning of stalk residue into seed furrow. Like some others already stated, a good sharp pair of furrow double disc openers will suffice. NOTE: Before planting season, do the business card trick to know if disc are too worn or require shimming. https://m.youtube.com/watch?v=8OL19cUOgJw Now take the money you’d used to buy no-till coulters & buy a complete set of Keeton SEED FIRMERS. These offer a more consistent seed depth in furrow. If your planter’s double disc openers are sharp & shimmed correctly, they’ll cut an even seed furrow into consistent soil moisture. No-till coulters can mix top surface dryer soil into moister soils & allow seeds less contact with even soil moisture in furrow. Make every seed count! Edited by AC7060IL - 19 Apr 2019 at 4:45am |
Tbone95
They're a lot like the ones shaping up 25 days from now!
FREEDGUY
Sadly I have a bad feeling about a "repeat" after seeing the 15 day 'cast
SteveM C/IL
Orange Level Access Joined: 12 Sep 2009 Location: Shelbyville IL Points: 7970 |
The guys at New Ag Talk say get rid of coulters and advise use of trash whippers.
In certain hard soil no-til conditions, the lack of a no-til coulter will cause a lot more wear on disc openers by themselves.
CBnwo
Bronze Level Joined: 11 Sep 2018 Location: Ohio Points: 18 |
I farm some ground that wouldn’t let just the disc openers do the job.... but we’ve never seen an issue with the no till coulters
FREEDGUY
I was able to get into the barn yesterday(Easter Sunday)and got hibernating engines fired up for the first time since mid-November and took a glance at what would be involved with removing the entire N/T coulter assembly. Sadly it is NOT as straight forward as I had hoped, the aftermarket row cleaners are attached to the coulter arms . I suppose I could remove the coulters from their "arms"??
shameless dude
Orange Level Joined: 10 Apr 2017 Location: east NE Points: 13611 |
I have them for my 6 row, but have never used them.
Tbone95
Yeah, you should be able to just remove the "axle" bolt and leave the arms there....
FREEDGUY
Thanks Tbone
otis3
Bronze Level Joined: 22 Apr 2019 Location: tamms Points: 28 |
i have notilled lots in the past.a mistake a lot of people make,me too till i learned the hard way,coulters should not go any deeper than your going to plant.maybe shallow by half inch or three eights of plant depth.
fourthgeneration
Bronze Level Joined: 03 Jan 2017 Location: ohio Points: 170 |
We have soil that works without coulters but we have soil that new openers will not penatrate to the proper depth without. We have a 6606 and I alway lift the bean units up when planting corn.
Post Reply | |
