Non-Orange Grain Drill ID ? |
Post Reply |
SGTJ
Bronze Level Joined: 15 Apr 2019 Location: La Valle, WI Points: 106 |
Posted: 28 Mar 2020 at 11:30am |
Can anyone help my ID this grain drill? My Father-in-law is giving it to me and he said a couple blades are broken off -- looking to figure out the model and such so i can get a manual and order parts . Its a 10' drill.
Also planning to use with my WD - but i see TWO hyd. Lines |
WD , CA
DiyDave
Orange Level Access Joined: 11 Sep 2009 Location: Gambrills, MD Points: 50581 |
If no response here, take the picture to smoke stack or red power forums...
Krazy Karl
Silver Level Joined: 12 Sep 2011 Location: SE MN Points: 203 |
As far as cylinder goes remove the line from the rod end and put in a vent plug
steelwheelAcjim
Orange Level Joined: 06 Dec 2009 Location: Blissfield,Mi Points: 1257 |
I think you have an early No. 10 with hydraulic lift. They also came with clutch lift.
Edited by steelwheelAcjim - 28 Mar 2020 at 6:26pm |
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
AC Steve
Bronze Level Joined: 26 Feb 2020 Location: Dayton,Ohio Points: 20 |
Probably a Model M , is there a seed rate chart inside the box lid ?
AC Steve
Don’t think it’s a 10
steelwheelAcjim
In all my years of jockying machinery, i never seen an "M" with hydraulic. Unless it was "rigged up". Early 10's were an improved "M". The had a big "10" decal on the end of a red painted box. Later, they redesigned them with a bigger seed hopper and painted them cream and added 20 in wheels. |
Keith M
Silver Level Joined: 17 Mar 2020 Location: Kentucky Points: 50 |
Not an expert. A man I worked for growing up had a McCormick model 10 with both hoses on cylinder. One day a neighbor asked why he had both hoses hooked up. His reply, “ I don’t always get my clover seeded when ground is perfect. So I figure it will give me a little better penetr with disc openers. I’m not sure but I had the hose and it’s not eating anything. “. Sounde good to me as teenager but idk how much it helped.
Michael V (NM)
Orange Level Access Joined: 12 Sep 2009 Location: NM Points: 2335 |
sorry, I'm no help with the model... most drills that I have been around that type need a 2-way cylinder, ratchet jack, manual levers or something to put down pressure on the openers, otherwise they (seed openers) will just ride on top of the ground. the tension is set by the springs on the rods that connect to the disc openers..so with that said,,, a 1- way cylinder will not work...
BTW,,,nice lookin drill Edited by Michael V (NM) - 28 Mar 2020 at 9:36pm |
Post Reply | |
