noisy 17
jlogli View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jlogli Quote  Post ReplyReply Direct Link To This Post Topic: noisy 17
    Posted: 08 Mar 2012 at 7:05pm
I have a 1961 d-17 with a noisy bearing growl.  It happins in 1st,2nd and 3rd gear but not 4th, both in high and low side.  The housing that contains the hand clutch gets really hot after running her for awhile.  If i put the foot clutch in going down a hill the noise stops.  Any ideas?  Thanks.
1945 WC on full steel, WD wide front, WD45 power steering, 1966 D-17IVfactory 3 point.1967 D-17IV SC. 1973 rotobaler white top. orange top roto, model 90 combine,82S, four bottom plow.302 baler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 7:15pm
Countershaft bearing in the transmission for the noise (bad rubber gearshift boot lets water and dirt in the tranny) and the hand clutch compartment getting hot is another issue.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 8:02pm
If it is the countershaft bearing don't let it self-destruct, otherwise you may be looking for a new rear housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 8:49pm
What is the easiest way to diagnose the bearing problem. My 170 does the same thing with the noise in tranny. Really annoying. Thanks Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 9:10pm
Noise in the tranny ?? or a bad howl when running down the road in 7th or 8th gear??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 10:19pm
Kind of sounds like tranny or final drives. It does go away when you depress clutch and it free wheels. You can feel it in fenders at times. Tractor sat about 20 years in a barn. It does sing when in high gear and traveling down the road, noise changes when going down a hill and louder when going up a hill. Any help appreciated. Thanks Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 4:36am
Those sounds are similar to my 175, and my rear housing has been replaced. I'm not sure how you would determine that bearing failure, It would surely affect shifting at some point I would think.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 6:21am
There are some One-Seventy's that have a terrible howl in the rear end when roading.....they've been like that since they left Milwaukee, unfortunately......nothing wrong or an impending failure, just noisey. Take the fenders off sometime and drive it......mucho quieter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 5:29pm
How can you tell if it is input bearing, or other bearing problems easily? Thanks Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 5:38pm
I would say tear it down and inspect everything would be the best way. Sounds like alot of work, but downside is if it fails, you are looking at $$$ to fix, if you can afford to lay the machine up, tear into it, and inspect it you'll be better off in the long run. Good time to replace seals, anything else needed also.
This page was generated in 0.095 seconds.
