No Fire Extiguisher, Gone in 15 minutes!
GT in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Topic: No Fire Extiguisher, Gone in 15 minutes!
    Posted: 25 Sep 2010 at 7:42pm
1955 WD45 we like to call Ruby
Post Options Post Options   Thanks (0) Thanks(0)   Quote GT in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 7:50pm
Local farmer was on the road coming through town.  He was turning the corner when the fire started in the hydraulic system.  It was fully involved in about 15 minutes.  Thank God no one was hurt.  Alot of the damage may have been prevented if he had a fire extinguisher on board...  Ya just never know.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2010 at 8:09pm
A fire extinguisher won't put down a fire started by hot oil. Not even a fire hose will stop it until so much water is applied it has cooled the hot oil and by then its been spread all over the machine and the road. It may stop the flames momentarily but so long as the oil is hot enough to ignite it will burn until there's no oil or no air. And the "tin" of that green machine is all combustible and it did.
Gerald J.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 12:26am
Seems like with the cost of a new machine anymore it would pay to have an onboard fire extinguisher system like used of big construction equipment.  If they were factory installed it would only add a few thousand $ to the cost.  Might lower the insurance cost.
Allis Express participant
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 6:46am
most combine fires end up like this. Dust and oil burn quick and there is no good way to get to them when they start
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 7:06am
A neighbor parked his tractor after shredding stalks about half way across the field. He walk back to a different tractor to chisel plow what had been shredded. When he came to a waterway he lit a fire to burn the grass off. The fire went down wind,burned across the field and fried the tractor that he had just left. A total loss,but insurance covered it. I wouldn't call that an accident covered by insurance, I'd call it having a DAHH moment.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 7:38am
I was catching corn the other day and the ole 9500 pulled up to dump.  Man did it have a good aroma.  It smelled like toasted corn stalks.
I told the operator and he just kinda looked at me and went back to shelling.  Next time it did not smell like toast.
guess that was one time that he skated.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 7:41am
A small fire can be put out if gotten to right away but as Gerald J said after a little head start its all over. While on a voluteer fire dept. I responded to two equipment fires, one was a 4020 JD it had started up front near the fuel tank. We chased it from one side to the other and fially got it but in hind sight we should haveused two hoses, one from each side.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 7:49am
It's still good practice to have an extinguisher on board, even if it may not save the machine it might save your life. A few years ago an elderly man burned to death in the cab of his tractor because of an engine fire. You just never know.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 9:28am
I good reminder to hose off chaff and dust regularly on your combine.  One less fire hazzard.
Kevin(Alabama) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin(Alabama) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2010 at 9:32am
Had a N5 burn a few years ago because parking brake was on. Burnt the combine, grain truck and acre of corn. had two fire extigushers and the man running my combine paniced and left them in the combine and they blowed up in the cab.
"I would die a thousand deaths before I would betray a friend."...Sam Davis, Nov. 27, 1863.....DEO VINDICE
