No. 3 Sickle Mower
mnickel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnickel Quote  Post ReplyReply Direct Link To This Post Topic: No. 3 Sickle Mower
    Posted: 04 Dec 2019 at 8:08pm
I recently got a AC No. 3 Sickle Mower. I thought it would make a neat attachment for my WC. It's in worse shape than I originally thought, though. I will need quite a few parts to bring it back to working condition. I have a pitman arm ordered through my local AGCO dealer, but I need a few more things. Does anyone know where you can get parts for these mowers? I need:
- The link from the lift to the sickle
- The tractor half of the PTO with shields
- The hand lift looks like it was fixed, or totally made from scratch at one point, so I need a new lever, guide or maybe even the whole assembly. Not sure. It might be ok the way it is, but it doesn't look that great.
Please let me know if you know where I can get any of these things. Or if you have it and are willing to ship to Canada!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2019 at 8:24pm
We have some nos stuff for that mower, let me know if you'd like us to look more into them.
Ray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2019 at 8:39pm
I have a lot of parts for those mowers. I do not think you have the proper mounting bracket for a WC tractor. I would have that, and other parts. 785-353-2392
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 9:36am
Looks like it may be part of the mount for a B or C. The mounting parts are tractor model specific.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnickel Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 10:35am
Thanks for help. Sure Mike, I’m interested in the parts, if you could have a look! I’ll phone you too, Ray.
I thought this was the mount for the WC. I’ll attach a better picture.
Edited by mnickel - 05 Dec 2019 at 10:36am
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 2:44pm
I got a length of oak from HD and made my own pitman.  The remains were there so I did have a pattern to use.  The No. 3 uses different adapters for different tractors.  I can't tell from your pics, but you may have the correct one for the WC.  I gave away my books to the guy that bought mine so I can't be sure, or that one may be for the B/C hook up.  The adapter I needed was for the WD/45, I found it on here and got it from a guy up in ID I believe.  Good luck with your mower.
In case you didn't know.  That bent rod down thru the center of the mower is for holding the bar up during transport.  You are missing the nut unless you took it off for safe keeping.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnickel Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 2:47pm
Thanks for the info! I knew that was what that was for, but I’m missing the nut.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 5:01pm
Sorry I stand corrected on the mount. It is for a WC. Sorry. I do have the pitman stick dimensions if you care to make your own. The link below is for your hitch. https://na.apb.agcocorp.com/p/agcoallis/9001530b/l/18?tocGuid=f422496f-6855-1a16-8cdf-4ad2299f6d23
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnickel Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2019 at 6:50pm
Thanks!
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2019 at 8:38am
I have the pitman stick in my NOS parts for $15.50 pn 802093, If you're interested. I don't have the lift link
www.awtractor.com
A&W TRACTOR 920-598-1287
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 1:33pm
Looks like it, except this one has a hydraulic cylinder on it.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 3:27pm
Here is one of his pics. It is a number #3. How did they have it mounted?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2026 at 4:08pm
The CA he had it mounted on was not a snap couple, the arms were turned down and a bracket went down and had a piece that went from arm to arm and was bolted to the draw bar, it had to mounting points and the arms that went down to the draw bar.  But mine is a snap couple, I did not see any cylinders on his lift arms????
