Nice 200 for sale-not mine
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Topic: Nice 200 for sale-not mine
    Posted: 07 May 2024 at 4:12pm
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2024 at 4:24pm
No air conditioning. that kills it.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 8:43am
Rear tires kill it worse for me than the lack of A/C!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 8:54am
rear tires are way to short it makes it look broke down .  what brand of cab is that one ,it is kind of bland and boxey looking  at least if it had a visor on top  but i would like to have a 200 it has to be a better 190xt
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 11:55am
La Porte cab. Non A/C. I have same cab. IIRC, the cabs with A/C did have a front visor and the evaporator is under a rear panel extension of the roof outside the cab
Edited by plummerscarin - 08 May 2024 at 12:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 8:45pm
Well I guess I am way off base, in my mind what can $6850 get you. Around here, not much.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 8:50pm
Allis Freak, I'll agree with you. just looking at the add, that seems like an average price if it's good mechanically.
The rear tires are small...
I'd like to have an open station 200. It like like the majority of the 200's I see have a cab
im4racin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote im4racin Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 9:05pm
Not all ac tractors have a front visor.  Looks like 16.9-34 tires for row crops. Probably has 3pt hitch. Price seems about right for that straight of a tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2024 at 9:43pm
around here 4000 will buy a 9n ford that you know when you get it home it will not start and it will have a flat tire
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2024 at 12:24am
The cheaper 200's had 16.9x38's on the rear,. There were several around here.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2024 at 7:37am
With the baler behind it, kinda makes me wonder if the small tires are to slow the tractor down a little while baling
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2024 at 8:18am
The "cheap" 200's had 16.9 or 18.4 x 34's on non-spin out rims and a manual PTO that was 540 only.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2024 at 4:19pm
Well, I have a "CHEAP" 1974 200 and it has hyd. PTO with 540/1000. Hollow front bolster. So, I guess it was how the dealer ordered it. With the hollow front bolster, the front crank seal can be replaced without rolling the front end out of the way. So, cheap isn't all bad.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2024 at 8:46pm
200's all had the hollow front support. That was a change from the 190XT.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2024 at 10:30pm
Sorry Doc, I thought that was a change when the "Price-cutter" 200 came out. What were the differences in the cheap 200? Single headlights in fenders I think, but what else. Mine is a "74" model and it came from factory with single lights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2024 at 6:29am
My reference to a "cheap" 200 was the way the local dealer spec'd one out.  34 inch non-spin out rear rubber and the manual PTO was a good start. The "cost reduced" version from AC was less lights, a cab without a front visor and all orange (not two tone cream/orange) and not sure about anything else.
