NH L425 skidloader
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Topic: NH L425 skidloader
    Posted: 23 Jan 2010 at 3:38pm
Can anyone tell me how to get to the fuel tank?  Need to replace the rubber line.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2010 at 8:48pm
I believe they hung the fuel tank from the factory roof and built the machine around it.  I had a older NH Skid steer and the seat lifted out and you could access the fuel lines from there.  Just after I sold it a rabbit ate the wire on the safety shut off switch, a real bear to get to and repair.  Told the new owner not to park it where the rabbits could get to it.  Found one in the engine compartment when I opened it.
Allis Express participant
Dean SW IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean SW IA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 5:50am
I need more info as to what line from where to where,I have 20+ years of NH behind me. Inever have droped a tank to replace any line,give me more info and will try to help you.
Dean SW IA
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jan 2010 at 8:21am
On our L225 you can pull the seat out by releasing the two latches on the front under the seat, and unplug the safety switch wire on the left front of the seat (left side viewed while your sitting in the seat), lift the seat and pull out.  You should be able to see the fuel line on the right side of the tank on the top (viewed as if your setting in the machine), and from there you should be able between working from behind and ahead reach the fuel line and replace it.  I don't know how bad it is in the 425 with the larger engine though.  If you need me to, I can take pictures of ours.
