NH 467 Haybine |
Post Reply |
wayne3
Bronze Level Joined: 03 Apr 2010 Location: S. Tier,NY Points: 18 |
Posted: 27 Jun 2010 at 6:17am |
Interested in proper roller adjustment.Looks like adjustment bolt underneath,in center. Which way should I turn it and how do I tell if its right. When I check the cut hay, I can't tell if rollers are working properly. What should I look for? Thanks for any advice.
allisorange
Silver Level Joined: 27 Mar 2010 Location: perkins, michig Points: 381 |
If your talking about tension on the rollers there is a crank on both sides for that. If you mean lining up the rollers there is an adjustment on the bottom sprocket that has 4 bolts that you loosen and line up rollers so they do not touch when running. That is the way are 469 is and I would think the 467 would be the same.
John Carlson
U P of MI.
Ken McGregor
Bronze Level Joined: 11 Sep 2009 Location: Strathroy, Ont Points: 142 |
I was always told that you hold a stem of timothy or alfalfa upright by the bottom of the stem. It should bend over at the "bruises" but NOT break off. That is a rough measure of the right roll pressure but it seems to work well
regards,
Ken McGregor
Post Reply | |
