Newbie to Haying, will be using old AC equipment30
rlrobinhood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Topic: Newbie to Haying, will be using old AC equipment30
    Posted: 20 Jun 2016 at 12:17am
Hi all,
I've never hayed before, so bear with me.  I have an old AC-829 pull type swather and will be baling with a AC-303 wire tie Bale Chief.  Both pieces of equipment had been sitting for some time, but I think I'm getting them going again.
My main questions right now are on the swather.  I've been working on it for some time and today got it running and cut about 30 yards with it.  I would compare the grass to CRP grass as it has not been grazed or cut for 1-2 years.  I ran the PTO at 540, and had the tractor in first gear.
Attached are some pics.  What do you think?  I've never hayed before, so this is the first windrow I have made.  And I have a TON of questions:
1)  Will my baler pick this up, or should I rake two of these windrows together?
2)  How wide and tall of a windrow should I shoot for?  My neighbors windrows are much taller and have much more grass in them, but he uses a bigger swather and I'm sure he irrigates much more effective and fertilizes.  I'm sure he has a much better baler too, lol.  What are your thoughts on this specific to my old AC equipment?
3)  How far off the ground should the cuter/sickle bar be when cutting?
4)  I'm in northern WY and its very dry here.  How do I know when its time to bale?
5)  Any other words of wisdom you have for me?
Many thanks in advance!!
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 12:44am
1. The baler will only pick up a windrow that is as wide as the baler pickup or narrower.
2. If you are shooting for dry hay to bale, then the wider the windrow, the better. The higher (and thicker) the windrow is the harder it is to dry.
3. Set the sickle to cut about 3 or 4" off the ground.
4. In Wisconsin, straight grass takes 2 full days of sun to dry, WY might take a little less.
5. If you are new at haying, don't jump the gun on baling, when you think the hay is ready to bale, wait a while longer then bale.
www.awtractor.com
A&W TRACTOR 920-598-1287
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 12:48am
Hello Mike, Welcome to the AC site... best in the land of Allis-Chalmers...the right place to ask questions. Sometimes its fast answers, and sometimes it takes awhile.
 First off, I am looking at your pics, I have never run an allis 'swather', which is actually called a haybine, because you are combining three actions into one... Cutting the hay, crimping/crushing the hay in the rolls and laying it in a swath of desired width.
 But anyways, the swath you are making doesn't look like it is going through the wings, more like just fgetting out of the rolls and laying down on the ground.
 Do you have a panel ahead of the wings knocking it to the ground?
 On the haybines I have used, I set the wings for the widths of the windrows and how fast for it to dry. wider the better for fast drying, narrower for keeping some moisture in if your not going to get to it right away... in a day or two but three of four...  Rain coming, and need to cut, layit wide so when the sun comes out, it will dry better.
 On the allis haybine, the drive that turns the rotary motion into driving motion for the cycle, is notorious for giving troubles. Make sure that gear box has oil in it at all times... and if its leaking, get it rebuilt before it gets ruined. no parts left for it except for scrapped units and they are hard to find. I have one that the box is gone on. Stern Smile
  We had an old haybne that we used and it was heavy , but it crushed the hay very well and layed it in windrows and we never raked the hay, but then we got a 990 IH that no matter what we did with it, the windrows didn't dry very well so we had to rake every thing if the hay was heavy.
Windrow for the baler is best if you can have it uniform in width size and density, but thats not in my world. and don't try to make any speed records either...  hope everything is in good condition on your baler... like the knife on the blung is sharp, nd of proper distance between the knives, and the knotters are well greased and not rusty... oh yea, you have wire tie never mind.. somebody else will have to tell you on the ins and outs of wire tie, I only dealt with twine.  And don't bale anything that is wet green, or you will be replacing shear bolts and having moldy hay or  worse scenario, bales that get hot and set the barn on fire. Good luck.
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 12:51am
looks like it's cutting good. i'm sure that size windrow will be just right for your baler. you can judge how fast/slow you need to drive in different conditions as to how things work the best. how much do you have to do? if you find a big rock...stop and pick it up! balers don't like them much. bale as many snakes as you can, the rest of them will soon leave to the neighbors! welcome to the forum! and don't worry about asking questions...that's how you learn! and shut everything down before messing with your equipment! and STAY AWAY from that PTO if it's running!
SLee(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 7:06am
I would open the wings and try to get hay to slide on them. They get rusty from non use and need polished up. Also there is a panel in front of the wings that is held up with springs, if I remember. Make sure it is all the way up when you are mowing. If you get it to make a good windrow you will be able to bale without raking. I always seemed to have better luck with alfalfa than grass. I'm sure your grass is different than mine in Iowa. We have mostly brome.
Steve
JimIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 8:30am
Looks good! You must have gotten that round belt in there to run the sickle.
If your sickle is in good shape you should be able to mow at least 5mph. The guy I bought my 829 from said you could mow easily at 6-7 mph in alfalfa. With that said you should mow at a speed you are comfortable with but I would mow atleast 3mph. Anything less and your machine will bunch the hay in piles due to material not running through at a speed slower than the reel.
Jim
Edited by JimIA - 20 Jun 2016 at 8:31am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 9:11am
There is definitely an optimum moisture for baling hay. As noted above too wet it molds, and heats. If it heats too much it takes the barn with it. http://kimt.com/2016/06/19/fire-in-rockford-destroys-shed-equipment/
Somewhere I have a forage crops book, I haven't found it today. I've not baled hay in 15 or more years. There is a number for moisture that is desired, but I don't remember if that's 5% or 15% or some other number. I would suspect today there is a handy hay moisture test meter. What I did a few times involved a sensitive scale and a microwave oven. I took a sample of the hay and stuffed it into a styrofoam coffee cup and weighed it. Then I microwaved it testing the weight until more time in the microwave didn't change the weight. The % moisture was the amount the weight went down. Of course I weighed the empty cup first.
The farmer moisture test is to grab a fist full of hay. Grab the hay with both hands and twist. If its dry enough for safe baling, it will break, if its wet it will hang together.
Hay that heats moderately can be calmed by opening the bales and applying salt.
My baler was a twine baler and for the misses I carried lengths of twine long enough to wrap the bale in the normal twine or wire position plus about a foot. I tied one end into a loop with a bowline knot. To tie a loose bale I wrapped this twine around the bale and pulled the straight end through the loop. Then except for friction I had a 2:1 advantage for tightening the twine around the bale and I tied the loose twine to the loop. I never detected one of those coming untied.
http://extension.missouri.edu/p/G4575 is an online page on making hay. They suggest 18 to 22% moisture at baling.
My quick google search https://www.google.com/search?q=hay+moisture&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a&gws_rd=ssl
turned up almost a million hits with many university extension bulletins on drying and testing hay, including a gaggle of moisture testers.
Gerald J.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 11:08am
The ideal hay moisture when baling is between 15% and 18%, I believe. Too wet and the hay heats and may turn moldy. Too dry and the leaves tend to fall off too easily.
BenGiBoy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BenGiBoy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 11:33am
Gerald J and DougS 18% moisture is too high for dry grass bales, it will be 30% or higher after you bale it and it sits for a day or two. And HOT. If you are making dry hay (not baleage) you want it at about 8-10% when you bale it, then it wil go up to about 13-16% and it will be okay. At least that is what we do at the farm I work at, I don't know if it is different out west.
We have a moisture tester like this one too poke into the bales after they are baledDelmorst F2000 moisture tester. And our balers have moisture testers in them that connect to a monitor inside the tractor.
'39 Model B
Tractors are cheaper than girls, remember that!
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 11:37am
For starting don't worry about too dry you probably can't over dry it simply because it is hard to get enough good weather to dry it in the first place at least that is the case here in nh. It it is wet feed it out right away. Another good test is see how heavy the bales are a good square bale about 30 inches long packed pretty tight so it holds its shape when you pick it up will weigh in at about 50 to 60 lbs. If it is about 100 plus the hay is too green or wet however you want to say it. I have always used twine balers so I can't speak to a wire tie but I would agree with Shameless that you probably don't want to rake it together too much hay is alot worse a problem for a baler then too little. Both can cause issues depending on the baler but I would start with a single raking and see how it goes. I mow early in the day Ted the hay mid afternoon and about noon the next day depending on how fast it drys might start baling about 3 the second day maybe noon the third. If you don't have a tedder you will want to rake the hay over once the next day after the dew is off or the bottom will never dry. I can't really dry hay here without a tedder even though I have been told time and time again how it was done in the past. I also remember alot of moldy hay in the bar as a kid and feeding it to cows when the bales where so hot you couldn't hold on to the stringd. My experience is that moldy hay won't burn a barn or the old barn here wouldn't still be here. I think most of those storied are people not wanting to admit they smoked or dropped a gas light in the hay loft. I am sure alot of people will come and say how they know of a barn that burned from moldy hay but here is the thing water doesn't burn and it is the only reason it molds. So take a match to your compost pile and tell me how well it burns... point being if the hay is wet when you bale it feed it to cows or goats right away you get abiut a week before it really starts to mold anyway.
Good luck that mower looks to have done a good job.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 1:05pm
Dan, I understand your point of view, and you are correct, water doesn't burn. But the drier hay around the hot hay will! Meaning, hay put up good 1 day, greener hay the next, or hay put up good in the afternoon, but went too long into the evening, or a big slug of hay didn't dry correctly. My dad was on the fire department for decades and chief for a very long time....I suppose every case of wet hay burning a barn could be a lie, but I don't think so. I've seen black char on hay, some that we baled, some that we bought, too close for comfort in my book!
Edited by Tbone95 - 20 Jun 2016 at 1:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 1:14pm
Tbone95 all I can tell you is if moldy hay can start a barn fire my uncles and grandfather where the luckiest guys around because they put a lot of bad hay in the old barn when I was a kid and the barn always had a mix you tried to feed out the moldy stuff first so the heifers would eat it. I remember stacking hay over to sort out the good stuff as a kid. Don't know what else to say but it makes me question the stories as I remember otherwise here. That said i try very hard to get the hay dry or feed it right out myself no point in wasting good hay by cutting it when it rains...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 1:26pm
It's all good Dan, I hear you. I'd say conditions have to be absolutely "perfect" for the fire to start, but I do believe it's possible. I've seen plenty of mold too....I remember a time when I was probably a teen, we were feeding some stuff baled wet (didn't put it in the loft). During like the 3rd day, it was so hot it would burn your hand if you touched it. Honestly wasn't sure if I was seeing smoke or steam, and you could see black char. That was as close as I want to come to proving the theory. Obviously, if something is wet enough, it won't burn (silage!), but like I said, if there is super dry hay next to a super hot spot, and it gets a whiff of air at the right time, I think it's possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 1:31pm
Just one of many sites: http://www.cattlenetwork.com/cattle-news/Baling-tips-for-superior-hay-quality-203638261.html
Google is your friend, but check several sources.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 2:41pm
Maybe part of my grandfather's luck was that he baled them as heavy as he could get the strings to hold. I don't think there could be any air in his hay....
I have seen both those black bales and the white ones. I dislike the white mold alot more then the black at least you can breath around the black hay and yes them bales are so hot they feel like they will burn you but that is probably about 160 I think if it gets much hotter then that the mold dies. That is why they claimed that silage would cook not mold. I think that is probably true because we had trouble packing our bunker silo one year and it was nasty a little deeper then normal maybe 2 feet down instead of the normal 12 to 18 inches but below that it all just cooked into silage even though it wasn't packed that tight.
I don't miss that bunker silo only way to cover the ground we did with a crew you could afford but it always stunk here with that system. Dry hay is much better feed if you ask me.
Oh as to handling the moldy hay I have been told you really need a mask for the white ones that mold isn't healthy to breath in. Another good reason to feed them right out...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 2:45pm
Oh have you ever tried to pitchfork off the top of a bunker silo when it is 90 degrees outside? I actually had it melt the soles of my hiking boots before I gave up found that out when I got down and they squished on the cement.   Weirdest thing I ever saw never thought it would be hot enough at the top of a big hill of grass to melt your boots...
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 8:36pm
Something tells me getting it dry is not the problem,just look at the hills behind all dry not green. Easy to miss the day that is perfect here in the west. Just wait for a dew on it before you bale. I have seen grass hay lay for months and still be very good hay,when baled with a good dew.
Since you have a neighbor that is making hay may be better to follow his example than advice from us 100's or even 1000's of miles away about how dry it is. In general does not dry as fast in the west it seems to me. But if you water your hay ground you need it off so the water can go on. Have a cousin moved to Idaho,on alfalfa they water leave it until for sure dry then bale only at night to save leafs.
About the hay catching fire I would like to believe Dan but sure would not depend on it. Twice I have had hot hay both time old hay that had no mold. The landlord left a door open and cows got to 100 + bales for days and stood on top of hay and peed as they ate. She called in panic had to get hay out before her barn burned. It was very hot pile about 4 foot high. Pushed it out with a loader,could see steam or smoke puffing out you would get load broke off to push outside.Never say any chard black so I don't know.
Second time had a real Pacific coast rain storm.Flipped a 30 foot section of lean-to off barn allowing wind to blow the rest of the tin off that end of barn.With mud and flooding took 2 weeks to get wet hay out as no where to haul it to.Loaded it by hand it got hot through gloves in 40 and 50 degree weather.Again when bales opened as we dumped them a puff of something would go up,but again black charred hay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 11:06pm
Steve
Hi SLee,  I do have that panel and it is held up with springs.  I'm thinking that because the tractor was going so slow, the cut hay was falling out before it got to the wings.
With that being said, I can't cut anymore until I get my baler going.  Hopefully this week.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 11:09pm
Jim
I think you're right Jim.  I need to go faster.
For the belt, I havn't replaced it yet.  It looks horrible, but is working.  I did order a belt and got it yesterday just incase it breaks.  Many thanks!!
Taylor in Indiana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Taylor in Indiana Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 8:48am
I don't have anything helpful too add, But can i say for a flatlander like me that view is beautiful!
1941 B 1957 D17 1968 IH 3514 Early 190XT Gleaner F
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 10:30am
Dan, I have been at 4 barn burnings, two of them were just the farmer that worked alone and did not smoke, but the one was notorious for trying to get his hay baled as soon as he thought he could bale it... and was usually wetter looking than what we baled. - One barn fire, the neighbor said that he seen the renter go by with wet green bales and that he hoped that fellow was going to feed them right away... about a week later the barn went up in smoke. - Another fire was on a bigger farm and the help had gone up into the haymow and said he could smell smoke, and threw some hay down the chutes and  there was one chute that had the smell of hot hay coming up it. an hour later the fire broke out into the chute and the call to the fire department was made... many neighbors showed up and we tried to get the cows out of the barn, cows that were never use to being let out and in the fire they were running back into the barn... Fire dept hosed some of the cows off when they came out but most of those burned were already to fried to be saved. - Then there was one barn fire that they speculated that it was lightning that set that one, but the adopted kid was notorious for sneaking smokes too... don't know. - We had hay we thought was fit to bale but just on the verge of it and had to get it in before the rains came. That was hot hay, couldn't hold your hand in it. left it in a pile for couple days and then mowed it away single layer across the barn and put salt on it and then put the next layer down and salted that. it finally cooled down enough to where we felt safe about adding more into the barn.
 T-bone ". Obviously, if something is wet enough, it won't burn (silage!)"  have you ever heard of silo fires?  seen a couple of them one from a stave, one from a poured. then there was a blue silo that had a severe air leakage in the base (from bad construction practice by the builder) that had silage so hot in it that when unloading it, it would steam, then it started showing white ash and mold and feed was toxic that it was stopped being fed to the cattle, so about 30' were left in it. in the spring, nothing but white mold came out of it and spread on the ground in a corn field about 4" tall, the weeds under it didn't grow and didn't need to cultivate where the molded silage was spread. Silo was junk and came down in just one year.
 Different hay has different characteristics in it, timothy hay is small stem plant and thin leaves, dries fast, mix grass is usually thin stemmed too but alfalfa with so much leaves and a stem that holds moisture as well as clover you have to make sure that is really dry enough to bale. Well at least in this part of the country.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 10:43am
Some grasses have a thick stem and a waxy coating. This is very hard to dry. FWIW there were more barn fires when hay was put up loose as opposed the when it was put up baled. You'd think the opposite would be true. BTW 15% moisture is not that wet. It's the target moisture you shoot for with grains.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 10:57am
JC - silo fires - yes, of course. Like I said, anything where the conditions are right to burn, it will burn, that's a fact of science. Heat, air, fuel = fire.
Loose hay, I totally believe it. Air gets to the hot spot easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 10:32pm
Hard to put together a couple good days for haying in our area of the country. We were always very careful about any wet bales (heavy) and those were set aside and did not go in the mow. Neighbor never baled any hay that had gotten rained on. Was afraid of it. His dairy barn burned due to a chain on a elevator coming off and throwing sparks into chaff below.I was in the barn trying to get cows out when the fire was raging in the loft above and embers were falling through the floor. It was no a pretty site. Several cows were lost in that fire along with a very nice barn. I think the thing that helped me was the Stetson I was wearing. Took years to get the smoke smell out of it.
I will be mowing aways hay in the morning for a friend that make 2000 bales for his beef cows. Yep ,time to lose a couple lb's!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 10:54pm
Chris it is scary as heck when one of the hay conveyors starts throwing sparks into a barn. Ours did that in the 80s I have a uncle in law who was up there and he can't look at the barn without remembering that day. We where lucky I was actually standing by the switch as they had just told me to turn it on so when they started yelling I didn't know what was wrong but I shut it off quickly. Lucky my uncle and his brother in law where able to throw the bales under the conveyor out the back of the barn and in our case nothing caught on fire. But I still remember that story and it is in the back of my mind when I think about when I will store hay. That is just one more reason I don't really want to put that conveyer back into use. For now I don't need to maybe in a year or two that will be different when I get the rest of the fields opened up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 11:08pm
Just thought of something else. There is a white cross bar in front of the reel that can be adjusted for height. It should be adjusted low enough to push the crop over a little as you drive forward. That lets the reel grab the crop as it is cut and feed into the rollers bottom first. Seemed to feed much better that way. We also ran ours with the wings wide open. The baler could still pick up the windrow and it spread out a little bit so it could dry faster. Hay could slide through the wings better since it was more of a straight shot.
Good luck getting your hay up.
Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 11:21pm
We don't do this on a regular basis, but when we have some hay that is baled wetter than we like, we will stack the bales with salt between the layers. We get some 50 pound bags of feed salt and will put down a layer of bales then scatter salt on it before putting down the next layer. Hay has always come out dry and green with no mold. Some in our area plan on doing hay this way. We don't but if we have a couple loads not yet dry while trying to beat a rain, it works good for us. Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 11:33pm
Steve that is a neat trick with the salt never heard of salting hay before but I can see how it would work kind of like salting fish. The plus with hay is that the cows need salt anyway so a few bales like that would actually be good for them or atleast not bad. They can eat mold some even like it but I hate the idea of feeding it to them so far I have been lucky and able to feed out the wet hay faster then it would go bad. I do have a couple of places I can't dry the hay. Working on opening those fields up to get light in there right now I just cut those sections slowly so I can feed it out. Have to keep the salt in mind how much per bale as a rule of thumb?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SLee(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 12:13am
Dan, that's a good question. Since we only do it on a load or two, we put salt on probably heavier than it needs. Just being safe.  Don't quote me but I think I heard that a couple hand fulls per bale is enough. We are probably putting 2-3 times that. I'm sure it depends on how wet the hay is.
Steve
