Newbie from CA
Rickjr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rickjr Quote  Post ReplyReply Direct Link To This Post Topic: Newbie from CA
    Posted: 15 Nov 2025 at 6:24pm
Hello everyone,
My name is Rick Jr., and I am a new member from California seeking some agricultural advice.
I currently operate a 3-bottom International plow that does not have a gauge wheel attached. I am trying to determine if it is impractical or ill-advised to plow without this component, particularly when working in relatively dry, light soil conditions.
My main question is: If I set the depth controls on the tractor, can I expect the plowed ground to remain reasonably level and consistent without the aid of a gauge wheel?
Thank you in advance for your help and expertise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Nov 2025 at 6:41pm
tail wheel makes it easier to set the depth... but a lot of 3 bottom plows in use without one.... Depends on the tractor and ground conditions... all you can do is try it and see the results..
Edited by steve(ill) - 15 Nov 2025 at 6:47pm
