New well at barn Friday
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: New well at barn Friday
    Posted: 24 Jun 2023 at 4:04pm
Been awaiting this as was worrying with new wells all around the two springs up the valley may shut off.    Drillers were completing as I returned from Town Friday so stopped in to see what was doing.  All complete, were gathering up Cribbing and tools, 6' Mud Bit to Stone drill, 140-150' hit the white sand layer and water, drilled on to 340' for buffer as usual.  As was speaking with driller he added the tablets they do after drill could hear plop plop as hit water, was only 7' below top of mud casing.  Said was likely a better well than anyone else nearby has.  Went down this morning to retrieve the 180, stump to pull and a few shrubs wife is done with, could hear running water.  Well is Artesian.
Fitters will add drain line to creek pool behind barn for casing then set two hydrants, the surge tank and a Cattle waterer system, should not have a issue with water from now on!!!
Edited by DMiller - 24 Jun 2023 at 4:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2023 at 7:04pm
Looks like you made out good on that one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2023 at 7:41pm
Yes we did.  And as dry as has been get two prizes, a damned fine well and a auto feed into the Creek pool the cows use daily.
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 5:09am
Yes we did.  And as dry as has been get two prizes, a damned fine well and an auto feed into the Creek pool the cows use daily.
Yes two prizes for sure. Can’t beat that deal.
We’ve been dry this year too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2023 at 5:11am
Field grass and clocer have returned to dormant, cows are walking the entire place in search of Green as well shade. MAY get some light rains by Wednesday, maybe.
