New voltage regulator ????
steigerbro24 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steigerbro24 Quote  Post ReplyReply Direct Link To This Post Topic: New voltage regulator ????
    Posted: 16 May 2012 at 6:04pm
I'm gonna go and buy a new voltage regulator and I wanted to know if the generator mounted regulators are better or the ones that sit below the generator (which is mine). Also is it too difficult to replace it.
Thanks Peter
5 Steigers, 7 John Deeres, 8 Internationals, 4 Case tractors and combines and 1 Oliver
........... Oh wait they're all 1/64.......and a real '44 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2012 at 7:18pm
The little box that was original to the B and mounted on the genny, was a cut out relay and needs a 3 position switch with a resistor to work properly. If it has been converted to a voltage regulator, it should be no problem to switch out the old one for a new one. There are different styled regulators also. You're gonna have to match up to what you have to make it simple to change.
