New use for bumper jack.
junkman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Topic: New use for bumper jack.
    Posted: 25 May 2011 at 6:18pm
When I junk older model cars, I always look in the trunk for the jack. I have 4 or 5 and always come in handy for lots a lots of things even use them to break the beads down on my tires. But today I found a new use that I figured I would share for those that might find themselves in the same predicament.  Finally located a 18.4 28 tire for my d17. It was used but it still had the center in it and it was mounted up for the side I needed. Thought it wouldn't take to long to change out, yow right. don't think they had ever been off since new. Tried every thing even the impact, but to no avail. I knew the 3/4 break over would do the trick but couldn't figure out how to hold it on the lug nut and work the cheater pipe at the same time. Then the bumper jack come to mind. Worked like a charm.
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:04pm
I think the bead on that tire is trashed...IMO. Luke
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:50pm
Yes that bead was trash. I never had one do that before. Ive had a many come apart but never just break. Made for a fun ride to the work area.
Breeze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Breeze Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:06pm
it is amazing what we can do when we get in a tight, the brain starts working overtime. Well, for some. Good idea.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:07pm
Some times you got to work 'smarter, not harder'!  Good thinkin'!
Greg Kroeker
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:22pm
Yea, I am starting to think that way too... as my older brother says...using your brain instead of breaking your back
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:35pm
have you got a photo or explaination of how you use the jack to  break the tire bead off  a rim ?  Do you have a clamp to the center hub ?  I have done this, but normally have trouble with jack or C-clamp sliding off to the outside of the tire... got a better way to hold it up against the rim ??
se iowa picker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote se iowa picker Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:38pm
looks like a winning matter, brains over brawn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote junkman Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 8:59pm
Steve for breaking tires down it is best to get one and weld the base onto the jack. then position the tire beside something like the front of your tractor to where the jack and bead are just a little over parallel. For you will want to drive the foot of the jack back under the rim and onto the bead once the foot clears the rim. Once in a while you might have to use a wedge or tire spoon to work the bead off on around the rim but most of the time it will break down the first try. Don't know if this helps of confuses, but here you go.
