new truck question |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25221 |
Topic: new truck questionPosted: 24 Mar 2026 at 6:31am |
curious.... if you have the radio set 'kinda high' then shut of the truck, when you restart the truck does the radio come on 'kinda high' ,low volume or not at all ?
Joined: 11 Sep 2009 Location: illinois Points: 90730 |
Posted: 24 Mar 2026 at 8:19am |
on my 2013 F150 .... radio , heater, blower motor all come back at the same spot where you left it. ... same on 2019 FLEX.
Edited by steve(ill) - 24 Mar 2026 at 8:20am |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 24 Mar 2026 at 8:57am |
Seems like I have encountered one vehicle either of my own or somewhere in the extended family at some point that if the radio was left on it came on at a default volume…..seems a long time ago and no clue what vehicle it was.
Posted: 24 Mar 2026 at 9:28am |
well... this is what GOOGLE said....
2024 Ford F-150 owners report that the radio volume often resets to a default level (typically around 7) upon starting the truck, regardless of the volume setting when it was turned off. This behavior is a common complaint, often attributed to Sync 4 software updates and appears to be a consistent issue rather than a rare fault. For the 2023 Chevy truck (Silverado/Colorado), the radio volume is intended to remain at the same level as when the engine was turned off, but in practice, many users experience issues where it defaults, resets, or goes silent upon startup.
Edited by steve(ill) - 24 Mar 2026 at 9:32am |
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8401 |
Posted: 24 Mar 2026 at 9:35am |
Our ‘95 Suburban had a feature that would automatically adjust the sound system volume to compensate for road noise. It was a dial that sat behind the volume button, you could adjust that dial to increase/decrease that feature.
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25547 |
Posted: 24 Mar 2026 at 9:40am |
FWIW, my 24 Silverado remains where set
it is standard radio system Edited by LouSWPA - 24 Mar 2026 at 9:41am |
I am still confident of this;
jaybmiller
Posted: 24 Mar 2026 at 9:45am |
my wife's 1019 Nissan stays where it was , LOUD,as she plays it LOUD. I get in to move it ,start, then 3-5 seconds later get BLASTED ! 1-0 doesn't shut radio off volume control is useless for a few seconds. HATE starting it up... yeah, old and cranky BUT it's a safety concern. NO WAY should the radio come on,let alone BLARING.....
Tbone95
Posted: 24 Mar 2026 at 10:09am |
No way should the radio come on? Gosh, the 1970 IH pickup we had came on, because you know, in the good old days when you had to turn the knob that’s the way it was. You know, the days we should go back to. I use that truck because it’s the oldest thing I drove frequently.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35630 |
Posted: 24 Mar 2026 at 10:33am |
Newer than 2012 the chances are will come back to whatever preselected volume was at UNLESS Battery Goes Dead. Had this occur on Wife's 2017 Explorer, battery shot craps, she opened door and no lights, no Alarms. Was down to 3.9v at battery. Replaced Battery and she had to reestablish all her preferences on Entertainment System and the seat positions. Some have PROM units in the Control Modules(8 in the noted Ford) however they do not always retain a trained point.
ACinSC
Joined: 16 Dec 2015 Location: South Carolina Points: 3250 |
Posted: 24 Mar 2026 at 10:34am |
Maybe I'm crazy but I always turn the radio off when I park
DanWi
Posted: 24 Mar 2026 at 1:31pm |
On the wife's trailblazer the all-wheel drive button stays on even when you shut off the vehicle and restart it, we verified that this winter. The stop light auto shut off over-ride button has to be pushed every time you start the vehicle. Usually remember to do that at the first stop light
When you start the 2025 trailblazer it just brings up the info screen and then you have to select the radio. I can't remember getting in it and the radio was playing.Edited by DanWi - 24 Mar 2026 at 9:01pm |
plummerscarin
Posted: 25 Mar 2026 at 11:21am |
21 Colorado here. Radio default to zero 95% of the time on restarts
DMiller
Posted: 25 Mar 2026 at 3:26pm |
Found this really aggrevating, Look under the Hoods of Newer than 2024 light trucks, TWO Batteries, ONE for Starting/drivetrain functions, the Other Diode isolated for ACCESSORIES.
