new truck question
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Topic: new truck question
    Posted: 3 hours 31 minutes ago at 6:31am
curious....
if you have the radio set 'kinda high' then shut of the truck, when you restart the truck does the radio come on 'kinda high' ,low volume or not at all ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 43 minutes ago at 8:19am
on my 2013 F150 .... radio , heater, blower motor all come back at the same spot where you left it. ... same on 2019 FLEX.
Edited by steve(ill) - 1 hour 42 minutes ago at 8:20am
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 5 minutes ago at 8:57am
Seems like I have encountered one vehicle either of my own or somewhere in the extended family at some point that if the radio was left on it came on at a default volume…..seems a long time ago and no clue what vehicle it was.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 34 minutes ago at 9:28am
well... this is what GOOGLE said....
2024 Ford F-150 owners report that the radio volume often resets to a default level (typically around 7) upon starting the truck, regardless of the volume setting when it was turned off. This behavior is a common complaint, often attributed to Sync 4 software updates and appears to be a consistent issue rather than a rare fault.
For the 2023 Chevy truck (Silverado/Colorado), the radio volume is intended to remain at the same level as when the engine was turned off, but in practice, many users experience issues where it defaults, resets, or goes silent upon startup.
Edited by steve(ill) - 30 minutes ago at 9:32am
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 27 minutes ago at 9:35am
Our ‘95 Suburban had a feature that would automatically adjust the sound system volume to compensate for road noise. It was a dial that sat behind the volume button, you could adjust that dial to increase/decrease that feature.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 22 minutes ago at 9:40am
FWIW, my 24 Silverado remains where set
it is standard radio system
Edited by LouSWPA - 21 minutes ago at 9:41am
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 minutes ago at 9:45am
my wife's 1019 Nissan stays where it was , LOUD,as she plays it LOUD.
I get in to move it ,start, then 3-5 seconds later get BLASTED ! 1-0 doesn't shut radio off volume control is useless for a few seconds.
HATE starting it up... yeah, old and cranky BUT it's a safety concern. NO WAY should the radio come on,let alone BLARING.....
