New to the Allis Chalmers Family
Chubby_Bunny_Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chubby_Bunny_Farmer Quote  Post ReplyReply Direct Link To This Post Topic: New to the Allis Chalmers Family
    Posted: 09 Jul 2017 at 11:53am
Good morning all!
Here I am on the eve of purchasing my first tractor for the farm, a '55 WD 45.  Seems to be in good condition, it's in farm ready condition.  The owner is done with the lack of hydraulic steering, and modernized a bit. We have 8.5 acres, plan on the majority of it in row crops.  Any advice as to what I should look for before I buy this fine piece of equipment?
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 2:56pm
welcome to the forum! make sure it starts easy, runs good, and everything works on it that you need it to! tire good? snap coupler hitch or 3-pt? if you don't mind me/us asking...how much $$$? others should chime in and be more specific!
matador View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote matador Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 7:37pm
I don't know too much about the older A-C tractors, but were the WD-45's prone to being gear jumpers? If so, you'll want to check that
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 9:10pm
Of course you will run it before buying so check (1) as said above the gear shift - put in third gear and move the tractor and slow rapidly.  See if jumps of gear (2) check the hand clutch to see if (a) clicks into pull position and (b) if releases when pushed forward, (3) check the brakes and see if they work - brakes can be replaced but it can be a problem (4) lift and lower the hydraulic - should go up and when moving lever down with foot pressure should go down (5) if possible check the lug nuts on the rear wheel sliding adjustment to see if loose - usually these are frozen but you may be lucky
Do the normal stuff check the oil and fluid levels and cleanliness of the tractor - can tell how well cared for - along with the general appearance of the tractor.
If good should be more than enough for your operation
Wish you the very best.
Let us know how it goes.
Welcome to the Allis Chalmers Forum
Good Luck!
Bill Long
Edited by Bill Long - 09 Jul 2017 at 9:14pm
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2017 at 9:36pm
I would operate the pto,listen real close for a clicking or ratcheting noise.those pto intermediate gears have been known to fail.i have replaced one on my 45 diesel and 2 more for other operators...just thought I would mention it ....that ole 45 is almost bullet proof.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 9:46pm
Welcome, and good luck with the purchase of the WD45. Good tractors!
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 11:55am
Welcome to Allis Chalmers ownership!  I have a '55 WD45 wide front gas.  You've already got some real good advice from the other guys.  Check the wheels for rust.  Older tractors that had fluid in their rear tires, and sometimes the front tires, too, may have rust problems on the wheels.  It might be anything from minor rust to a rim that's so rotted it has to be replaced.  Look for welds in places where they shouldn't be and any signs of amateur shade tree mechanic screw ups.  If previous owners thought enough of the tractor to keep it looking good and repair it properly it's less likely they abused it.  Check for a cracked block.  Those engines tended to crack behind & in front of the carb.  Check the antifreeze in the radiator.  A good WD45 will be a great tractor for you!
