new to me plow
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Topic: new to me plow
    Posted: 18 Mar 2026 at 1:01pm
i got this with a couple WD's I bought at an auction here in NM. I studied the plow ID on the knowledge base, looks to me to be a WD-#53 pick-up plow,, best measurements I get it's a 14",,  so I found an owners book on ebay,, looks like there is a lot of the adjustments are WAY off, first, the lift links are above the lift bar, next the pull bar and beaming adjustment are set too far to the RH side.  I gots the adjustments soaking,,
What ya'll think??
560Dennis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 560Dennis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 4:20pm
that is the hot set up .
Dave the plowman specializes in snap coupling plows .
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 4:28pm
Someone may have had that plow hitched to a D17 which would need longer lift links to not have the hitch hitting the bottom of the transmission case when fully lifted.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 4:44pm
That's nice. It was coverboards and moldboard extensions
Post Options Post Options   Thanks (0) Thanks(0)   Quote AMB(wcIL) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 4:48pm
The lift links need to be flipped over a half a turn on the hinge area. The bottom needs to be inside the U part. Andy
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 6:17pm
I have never had any luck soaking stuck plow adjustment threads... straight to the torch for me! However, being in your climate maybe you will get lucky? Definitely a 53 and a good save.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2026 at 7:43pm
Well,, John,, as rusty as this one is,,, it didn't come from NM...I'm sure the torch is gonna be the final answer....but,, I'm gonna give it a try...
Then,, gonna hafta spend a lot time with a grinder and flapper to shine up them moldbards..
Dave,, yea,, gots some nice 'extras',, be cool to find some jointers..
Edited by Michael V (NM) - 18 Mar 2026 at 7:46pm
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 7:21am
Good luck with the plow Michael!
1951WDNWWI View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 9:08am
After a couple rounds in rocky or sandy soil those bottoms will shine up.
Dennis J OPKs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis J OPKs Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2026 at 2:01pm
Spent many hours with one of those.  Both behind a WD and later a WD 45.  We plowed square fields in circles so the corners had to be rounded off-tough on the left brake.  Hope you get it functioning.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 11:29am
Michael, something that I've always wanted to try on rusty parts such as that, is heating em up, then melting candle wax into the threads. I've heard of success stories doing that, why don't you give it a try and report back on how it works, lol.
Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2026 at 10:36pm
ok,,yea, I know some sandy ground will polish them plows quick. the pictures really don"t show how bad the rust really is....
plan is,, get the adjustments freed up, set the basic book settings, do the LH wheel on an 8" block,,then I gots to find a neighbor that will let me come play with my plow..all my farm ground has been planted back to grass,, and as dry and windy as it is around here,, I'm not plowing up anything,,, I've had enough blowing sand around here....
