new to me plow |
Michael V (NM)
Topic: new to me plowPosted: Yesterday at 1:01pm |
i got this with a couple WD's I bought at an auction here in NM. I studied the plow ID on the knowledge base, looks to me to be a WD-#53 pick-up plow,, best measurements I get it's a 14",, so I found an owners book on ebay,, looks like there is a lot of the adjustments are WAY off, first, the lift links are above the lift bar, next the pull bar and beaming adjustment are set too far to the RH side. I gots the adjustments soaking,,
What ya'll think?? ![]() ![]() |
560Dennis
Posted: Yesterday at 4:20pm |
that is the hot set up .
Dave the plowman specializes in snap coupling plows .
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5271 |
Posted: Yesterday at 4:28pm |
Someone may have had that plow hitched to a D17 which would need longer lift links to not have the hitch hitting the bottom of the transmission case when fully lifted.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3124 |
Posted: Yesterday at 4:44pm |
That's nice. It was coverboards and moldboard extensions
AMB(wcIL)
Joined: 03 Oct 2009 Location: Chapin Il Points: 328 |
Posted: Yesterday at 4:48pm |
The lift links need to be flipped over a half a turn on the hinge area. The bottom needs to be inside the U part. Andy
wjohn
Posted: Yesterday at 6:17pm |
I have never had any luck soaking stuck plow adjustment threads... straight to the torch for me! However, being in your climate maybe you will get lucky? Definitely a 53 and a good save.
Michael V (NM)
Posted: Yesterday at 7:43pm |
Well,, John,, as rusty as this one is,,, it didn't come from NM...I'm sure the torch is gonna be the final answer....but,, I'm gonna give it a try...
Then,, gonna hafta spend a lot time with a grinder and flapper to shine up them moldbards.. Dave,, yea,, gots some nice 'extras',, be cool to find some jointers.. Edited by Michael V (NM) - Yesterday at 7:46pm |
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4270 |
Posted: 13 hours 22 minutes ago at 7:21am |
Good luck with the plow Michael!
1951WDNWWI
Bronze Level Access
Joined: 11 Jul 2011 Location: NW Wisconsin Points: 124 |
Posted: 11 hours 35 minutes ago at 9:08am |
After a couple rounds in rocky or sandy soil those bottoms will shine up.
Dennis J OPKs
Joined: 12 Sep 2009 Location: Overland Park, Points: 582 |
Posted: 6 hours 42 minutes ago at 2:01pm |
Spent many hours with one of those. Both behind a WD and later a WD 45. We plowed square fields in circles so the corners had to be rounded off-tough on the left brake. Hope you get it functioning.
