new to me plow |
Michael V (NM)
Topic: new to me plowPosted: 12 hours 21 minutes ago at 1:01pm |
i got this with a couple WD's I bought at an auction here in NM. I studied the plow ID on the knowledge base, looks to me to be a WD-#53 pick-up plow,, best measurements I get it's a 14",, so I found an owners book on ebay,, looks like there is a lot of the adjustments are WAY off, first, the lift links are above the lift bar, next the pull bar and beaming adjustment are set too far to the RH side. I gots the adjustments soaking,,
What ya'll think?? ![]() ![]() |
560Dennis
Posted: 9 hours 2 minutes ago at 4:20pm |
that is the hot set up .
Dave the plowman specializes in snap coupling plows .
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5270 |
Posted: 8 hours 54 minutes ago at 4:28pm |
Someone may have had that plow hitched to a D17 which would need longer lift links to not have the hitch hitting the bottom of the transmission case when fully lifted.
Allis dave
Joined: 10 May 2012 Location: Northern IN Points: 3124 |
Posted: 8 hours 38 minutes ago at 4:44pm |
That's nice. It was coverboards and moldboard extensions
AMB(wcIL)
Joined: 03 Oct 2009 Location: Chapin Il Points: 328 |
Posted: 8 hours 34 minutes ago at 4:48pm |
The lift links need to be flipped over a half a turn on the hinge area. The bottom needs to be inside the U part. Andy
wjohn
Posted: 7 hours 5 minutes ago at 6:17pm |
I have never had any luck soaking stuck plow adjustment threads... straight to the torch for me! However, being in your climate maybe you will get lucky? Definitely a 53 and a good save.
Michael V (NM)
Posted: 5 hours 39 minutes ago at 7:43pm |
Well,, John,, as rusty as this one is,,, it didn't come from NM...I'm sure the torch is gonna be the final answer....but,, I'm gonna give it a try...
Then,, gonna hafta spend a lot time with a grinder and flapper to shine up them moldbards.. Dave,, yea,, gots some nice 'extras',, be cool to find some jointers.. Edited by Michael V (NM) - 5 hours 36 minutes ago at 7:46pm |
