New to me HD11B |
Page 12> |
farmerdev
Topic: New to me HD11BPosted: 31 Jul 2022 at 5:25pm |
Recently bought an HD11B will be picking it up in about 2 weeks. They said the engine (685T) is locked up only paid $222 for it so I have some wiggle room in fixing it. I can get an engine rebuild kit for about $2500 less main bearing set & head gasket set. My question is should I keep with the stock engine or should I go ahead and repower it to a more common engine? I cant seem to find main bearings or head gasket set for this engine. Attached is a picture of the serial number.
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Posted: 31 Jul 2022 at 7:46pm |
I would investigate what is wrong with engine first. Could be something simple. JMHO, Tracy
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34617 |
Posted: 31 Jul 2022 at 8:45pm |
See if starter is locked up.
AC Mel
Posted: 31 Jul 2022 at 9:43pm |
Tim....So the serial number being 799...should be the first year of production 1955. It would have come with a Lonova style engine at that time...the 685T became the last version made. So ...yes JC and Tracy have good ideas where to look. As I always like to say....post some pictures....engine pictures will help identify exactly what you have....the more pictures the better.
farmerdev
Posted: 01 Aug 2022 at 5:25pm |
Posted: 01 Aug 2022 at 6:29pm |
Not a 1980's model 685-T for sure !!!! Non-turbo 1950's engine is what I see.
AC Mel
Posted: 01 Aug 2022 at 8:11pm |
So...Tim....yes what you have is the early version of the 685. This is the "Lanova" style Buda engine that was first installed in ACs in 1955. The hydraulics also represent the first year. Looks like a pretty clean specimen. Maybe put up some more pictures of the whole machine.
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 02 Aug 2022 at 8:08am |
Unfortunately no one is making engine parts for these anymore. I bit of know-how and luck will be required to find parts on someone's shelf.
farmerdev
Posted: 02 Aug 2022 at 2:21pm |
CAL(KS)
Posted: 02 Aug 2022 at 2:29pm |
definitely worth the price but the engine and undercarriage condition will be the determining factors.
R.KYLE
Posted: 04 Aug 2022 at 7:54pm |
IF YOUR UP FOR A CHALANGE A 471 DETROIT WILL FIT IN THERE. PARTS STILL AVABLE.
farmerdev
Posted: 05 Aug 2022 at 2:27pm |
I am up for anything really I do like the idea of a Detroit in there I have a 2-53 I believe in another JD crawler loader and that thing runs great. Just will have to find one I guess I may even just machine my own parts for this motor if I have to.
Lee Bradley
Joined: 13 Oct 2009 Location: Kingston, WA Points: 120 |
Posted: 05 Aug 2022 at 3:54pm |
Or you could go with a v-6
farmerdev
Posted: 06 Aug 2022 at 12:19pm |
That sounds nice. How much HP can I throw at the transmission and clutches before I break stuff?
Ray54
Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4873 |
Posted: 06 Aug 2022 at 2:20pm |
The tractor in the you tube is still running as far as I know, about 50 miles from me. The video has comment 13 year old and he only had 160 acres, so not run everyday. Farming is easier than dozer work because you use more higher gears.
So if you realize what the tractor was made to do and treat it with care, most anything that fits size wise. But remember if you break some parts there are no more at the dealership.
Lee Bradley
Posted: 06 Aug 2022 at 3:48pm |
Probably not as much power as AC put through them later with the turbo'd engines.
Codger
Posted: 06 Aug 2022 at 5:47pm |
here is a blurb on the series;
Codger
Posted: 06 Aug 2022 at 7:32pm |
My 11B tractor was rated at 140hp but according to my buddy at the fuel shop, fuel delivery is increased by 15% over stock settings. Mine is power shift however.
A complete AC 10000 series engine is about 2050 pounds complete. A Detroit Diesel 3-71 is 1521 pounds complete. A Detroit Diesel 4-71 is 1780 pounds complete. Power ratings are easily set where needed with most any of them. A 3-71, or a 4-71 would be a good choice for a repower I'd think. A 3-71 did a fine job in an HD7 tractor so a 4-71 should be a good match for the larger tractor. All would be just a bit more power than the original engine. If me I'd work with the original ascertaining what is wrong with it before going further. As mentioned, u/c and other major mechanicals need evaluated before going far.
Mikez
Posted: 06 Aug 2022 at 8:00pm |
Tim welcome to the forum. Is the pictures of the dozer at your property. See other orange in the background
farmerdev
Posted: 06 Aug 2022 at 8:15pm |
Thanks for all the information. The pictures of the Dozer are at the property I bought it from. I don't have it picked up yet going out in 2 weeks to get it. If I am unable to get parts for the motor I will probably get a 4-71 Detroit though the 6v-71 is tempting.
R.KYLE
Posted: 07 Aug 2022 at 9:08pm |
I PUT A DETROIT 671 IN LINE IN A HD11 LIKE YOURS. IT IS A TIGHT FIT AND REQUIRED SOME MODIFACTIONS. TRACTOR IS OVER POWERED BUT USED WITH CARE WORKS WELL. I USED THE 671 BECAUSE I HAD A HD14 WITH GOOD ENGINE AND POOR UNDERCARRIAGE.
CAL(KS)
Posted: 08 Aug 2022 at 7:10am |
would 11B have the early 1/2 bolts on the intermediate pinion cap? they were a weak point and eventually upgraded to 5/8, so power level considered here. keep in mind the v series will be more expensive than a 4-71 . they only ran about 1700 rpm, and a 4-71 will fit easier and definately be cheaper. I mean you can do whatever you want, i just feel the less complicated the swap is, the more likely it is to be a finished success, and thats what we want is another machine to keep on living.
Edited by CAL(KS) - 08 Aug 2022 at 7:19am |
AC Mel
Posted: 08 Aug 2022 at 10:32am |
I concur with Cal....keep in mind the year before this tractor was made it was the model HD9...which had the 471. There are very few changes in the running gear of this HD11 from the HD9. In the early years it was common for the farmers out here in the Sacramento valley to convert back to the 471 when they had engine problems. The 471 would be the easiest swap....if you found one with a turbo..that would make it sweeter. Be careful about trying to turn the engine over. Out of all the things that could be stuck...the PSB fuel pump could be one of the things that's holding it back. You don't want to break that....it is made of unabtainium...yes...been there done that.
R.KYLE
Posted: 09 Aug 2022 at 6:37pm |
YES THE 471 IS BEST CHOICE I ONLY USED THE 671 BECAUSE I HAD IT AND NEW IT WAS A GOOD ENGINE. ALSO MORE WORK GETTING THE 671 IN THERE.
danny1954
Posted: 15 Aug 2022 at 12:43pm |
HELP PLEASE!! i have a allis chalmers hd9b dozer that broke the u joint for the hydraulic pump at the crank shaft pulley. Cant find any information on hd9b with front mounted hydraulic pump. Need help finding manual and parts. Part # on tag HD-9B-3443
CAL(KS)
Posted: 15 Aug 2022 at 12:58pm |
take measurements on the yokes. measure bore for joint caps and width across to match it up.
not likely in parts book as a usable number now |
farmerdev
Posted: 22 Aug 2022 at 1:30pm |
Update on this dozer project. I was unable to load it do to the final drives being stuck. Anyone have any ideas on what to do to free them up? If not I will need to get a wrecker out to pick it up. I was able remove the blade and load it on my trailer. Here is a picture of a buddy of mine next to the blade for scale he is 5'10"
![]() And don't worry there are 4 chains attached to the back of that holding it in place.
Codger
Posted: 22 Aug 2022 at 2:24pm |
are you sure it is the final drives stuck and not either the tracks locked up, or the engine stuck with the transmission in a gear?
gemdozer
Posted: 22 Aug 2022 at 3:01pm |
You could remove the startor and try to turning the motor by the flywell ring gear with a big screw driver and make sure the transmission and hydrolic lever are in neutral fonction and you could desajusted the brake band these could be freeze on drum,
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35666 |
Posted: 22 Aug 2022 at 3:25pm |
In the photo the Right Brake was ALL the way depressed as if the Parking Brake was applied, did you release that? And lock back BOTH Steering clutches???
Page 12> |
