new to me d15 sr2
jtva View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtva Quote  Post ReplyReply Direct Link To This Post Topic: new to me d15 sr2
    Posted: 28 Jun 2015 at 9:39pm
I got this d15 sr2 this weekend off craigslist I was using it to bushog today and one of the power steering lines busted are these lines still available from agco or do I need to try and get a local hose shop to make something close. also would these d15s pull a 6ft bush hog or do I need to stay with the 5ft I have the wheels narrow as they can go and they are wider than 5ft . thanks jt
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 9:57pm
Nice looking tractor.
Yes, I believe most of the power steering lines are still available from AGCO.  While you are at it, I would recommend getting an owner's manual if you do not already have one.
As far as bushing hogging goes, what are you chopping?  It should be able to handle a 6', but you may need to go slower and use your hand clutch to creep through some of the thick spots.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 10:22pm
The right wheel looks like it will go in another two inches if you remove stop.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 10:37pm
Nice lookin D-15 NF
Mike Plotner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Plotner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2015 at 10:54pm
sharp D-15. Originals are always sharp looking. I've never had to get a D series power steering line, but I just had my local NAPA makes some up for the 190
At work, we pull a 6 foot Allis-Chalmers bush hog with a '58 D-14 and it handles it pretty well even in heavy weeds
2001 Gleaner R42, 1978 7060, 1977 7000, 1966 190 XT, 1966 D-17 Series IV and 1952 WD and more keep my farm running!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 4:55am
A D-15 can handle a 6' hog well.  As for the PS lines, Take old one to Colloflower shop, and have them make one up, they can duplicate most anything.  If you don't have colliflower nearby, you need to find a good hose shop...
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 6:02am
Love those tricycle tractors.  Especially the D-15.
Good Looking tractor.
Good Luck!
Bill Lon
playsindirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote playsindirt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 8:48am
Can someone tell me the part number of the weights on the rear rims? I would like a set for my 15.
48G 49B 67D15 35picker allcrop60 1973 rotobaler 49C
jtva View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jtva Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 9:24am
Thanks for the information. What are some good dealers to call about the power steering hose I'm in central va I don't know of any dealers around here. I liked cutting with it I was in real heavy grass up over the grill guard. It will take time getting use the the hi low hand clutch all the tractors I've ever used to cut with had 2 stage clutches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 11:14am
Good looking unit as not so many SII, 3-pt. with NF around. Factory 3-pt. on the D15 is not much more than the light components used on the D12's so keep all bolts/nuts checked underneath as routine maint., including the TB linkage.
Will have no issue with 6' brush cutter but you may want front slab or front wheel weights to help keep the front end safely on the ground since NF.
*Even with power adjust wheels fully in, you will not entirely cover the wheel tread with a 6' cutter as it will be 4-6" shy. I switch directions and cut the opposite way every other round if I really want a clean cut sometimes.
Be careful on any grades with that NF . . . . .
Rltool View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rltool Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 12:00pm
Nice looking D15. Don't see many of those around me.
Plays in dirt, look at the top of this forum category's page. There is a sticky post about Allis weights.
Ray W.
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2015 at 8:31pm
got mine from sandy lake a few years ago and they are pricey about 130 dollars
