new to me B-112 |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25281 |
Topic: new to me B-112Posted: 26 Aug 2016 at 5:23pm |
Finally got me a REAL garden tractor, a B-112.12Hp with hydraulic lift and 48" deck. Seems it's a 24 speed and has an 'odd' lift out back.
I'm looking for any links to get manuals and implement info. As I already have some cat0 3 point stuff(blade,1Fplow,cults) I'd like to use them..once I get her running . Jay |
ACmowerguy
Joined: 20 Apr 2010 Location: Winfield, MO Points: 1210 |
Posted: 26 Aug 2016 at 9:31pm |
http://www.simpletractors.com/Main/AC_models.htm |
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 27 Aug 2016 at 5:38am |
That odd lift is a sleeve hitch setup. There is a "U" shaped bracket that pins in the bottom holes by the pin hitch. That attaches to the implement with a pin. Top large hole gets a rod that does the lifting. If you Google sleeve hitch or Brinley hitch, you'll see how it works. I suppose a cat 0 3 pt could be fabbed up, but it really wasn't designed for that style of hitch.
The 24 speed is a variable drive setup. I guess it's a pretty temperamental setup from what I've read. Go here: https://www.simplicitymfg.com/na/en_us/support/manuals.html and punch in the model number 990494 to get a free op and parts manual. It'll be for the Simplicity version, but other that the seat and hood, they are identical. AaronSEIA |
jaybmiller
Posted: 27 Aug 2016 at 11:16am |
Thanks Aaron...great I got RID of the sleeve hitch stuff eons ago when I got some 3pt Sears stuff....sounds like I'll need to fab a 'sleeve hitch -3pt adapter...
QUERY : does anyone know of a sleeve hitch to 3pt adapter, even a picture will help ! Thanks Jay Edited by jaybmiller - 29 Aug 2016 at 6:20am |
